Author: Subject: BitTorrent
greggors84
posted on 6/12/05 at 12:26 AM Reply With Quote
BitTorrent
Can you download more than one torrent at a time using BitTorrent?
I can just change the queue order but only the top one downloads.
If not what is decent torrent downloading software?
Chris
The Magnificent 7!
jonno
posted on 6/12/05 at 12:36 AM Reply With Quote
i use Azureus http://azureus.sourceforge.net/
timmy
posted on 6/12/05 at 02:04 AM Reply With Quote
I use BitLord and found it very good. I commonly have about 4-5 on the go at any one time....
albertz
posted on 6/12/05 at 08:11 AM Reply With Quote
BitLord works well, download multiple files at the same time, no problems.
bimbleuk
posted on 6/12/05 at 08:23 AM Reply With Quote
I used Azureus myself but now use NNTP (news servers) instead much faster than torrents.
Danozeman
posted on 6/12/05 at 08:59 AM Reply With Quote
I use bittorrent. I have loads on the go at a time.
Dan
andyd
posted on 6/12/05 at 10:21 AM Reply With Quote
Ah so it's you Dan that's nicking all my bandwidth!
I use ABC for what it's worth and it'll download multiple torrents too.
Winston Todge
posted on 6/12/05 at 11:14 AM Reply With Quote
I've used Direct Connect and more specifically the DC++ client for the last few years. I've only recently discovered the RevConnect client and it is fantastic!
It enables the DC network to download a single file from multiple users and therefore absolutely maxes out your available bandwidth all day long!
4gig file takes around 5 hours on my 2meg connection... Absolutely joy to use.
On the original DC++ you'd have to be lucky or just spend awhile to find a single user with a quick connection, of whom would usually have no download slots. With RevConnect you can download say at 2kb/sec from multiple users to give you maximum bandwidth. torrents use a similar principal but I find very rarely that I can get anywhere near max bandwidth...
greggors84
posted on 6/12/05 at 01:36 PM Reply With Quote
Cheers Ill give a BitLord a go, for some reason it wont let me download more than 1 at a time. Also it sometimes says its behind a firewall, sometimes Norton pops up and asks if i want to allow the script and then its fine, but apart from that its quite slow.
Might give this direct connect a go, i tried DC++ before and like you never really found anything.
Chris
The Magnificent 7!
