<<  1    2  >>
Author: Subject: Fuel Tank Breather
Avoneer
posted on 10/12/05 at 11:53 AM Reply With Quote
Fuel Tank Breather
What have people used for a fuel tank breather and where can I buy one?
Pat...
liam.mccaffrey
posted on 10/12/05 at 12:02 PM Reply With Quote
cant you use a tyre valve?
[whisper]did you manage to order the DD2's[/whisper]
Build Blog
Build Photo Album
Avoneer
posted on 10/12/05 at 12:24 PM Reply With Quote
I heard that - but surely it has to let air in and out as you fill and use the fuel in the tank?
Pat...
mookaloid
posted on 10/12/05 at 12:25 PM Reply With Quote
I just used a bit of rubber tube, got it as high up as possible then down out of the bottom of the car.
No problems encountered so far
Mark
liam.mccaffrey
posted on 10/12/05 at 01:03 PM Reply With Quote
don't you use 2 one to leak in and one to leak out
Build Blog
Build Photo Album
piddy
posted on 10/12/05 at 01:24 PM Reply With Quote
I've been told you don't need a breather on the tank, if you fit a cap that can breath.
I'm interested if this is true.
Avoneer
posted on 10/12/05 at 01:26 PM Reply With Quote
Yep, that's true - but the ali aero cappy things are non breathers.
Two bike/car valves - that's two hole in the tank isn't it?
Pat...
paulf
posted on 10/12/05 at 01:32 PM Reply With Quote
I used a vented cap, but surely a bit of hose with a restrictor in it such as a .6mm mig nozzle, would allow air in and out but not allow fuel to leak to rapidly in the event of an accident , or two bike valves connected to a tee piece as used in windscreen washers .
Paul.
lsdweb
posted on 10/12/05 at 01:41 PM Reply With Quote
Surely one car (Schreider?) valve to let air in would be OK - that's what's on my car now. You wouldn't need one to let air out as you're filling the tank as you'd have the cap off?!
Wyn
emsfactory
posted on 10/12/05 at 01:48 PM Reply With Quote
I drilled a tiny hole in the back of the filler cap pipe.
only 1mm.
No probs.
If its getting laid up for a while just put some tape over it to seal it.
MikeR
posted on 10/12/05 at 02:24 PM Reply With Quote
Mate does fuel systems for a living.
when i talk about what we do his reaction is funny. It can basically be summed up as ......
Wave arms over head, look scared, repeat, "you're all going to die".
Now i realise he's being melodramatic but, he has to jump through hoops for a reason. How would you like to be upside down in a ditch with fuel pissing out of your tank onto you?
If you're about to say whats the chance of that i know of a number of people who've been in cars that have rolled!
bob
posted on 10/12/05 at 02:42 PM Reply With Quote
I had a think about what i could make or make do with,in the end i thought best to be on the safe side and bought a one way breather valve from thinkauto.
http://www.thinkauto.com
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=right_in_the_boot.jpg
[Edited on 10/12/05 by bob]
Avoneer
posted on 10/12/05 at 04:32 PM Reply With Quote
This is nothing to do with the car rolling over - that is something else.
This is to with not creating a vacuum in the tank so it doesn't collapse.
So basically, from the tube from the tank, I could fit a car valve upside down in the end of the tube? This would suck air in when the fuel goes down would it not?
Pat...
Mix
posted on 10/12/05 at 04:38 PM Reply With Quote
Don't forget the other function of the breather, to allow pressure build up due to expansion to be released.
Mick
Avoneer
posted on 10/12/05 at 04:47 PM Reply With Quote
Bob - what size pipe does it push on and has yours got a pipe coming off the side of it?
Pat...
MkIndy7
posted on 10/12/05 at 05:06 PM Reply With Quote
Maybe remotely relevent but not sure...
My dads Hyundai seems to work with a vaccume in the tank, when you fill it up after a drive you can actually hear it suck quite alot of air in as you unscrew the cap.
Maybe they can do this with injection, or it has another way of allowing air in if and when it needs it. (I suppose if you pressurise the tank it might act as a buffer to lessen how often the pump runs)
Might be worth looking at how manufactures prevent vaccumes in their systems, either at the scrapyard or in the Haynes.
bob
posted on 10/12/05 at 05:21 PM Reply With Quote
Pat
Mine is a regular piece of fuel pipe (8mm i think)
I just drilled and tapped a 1/4bsp brass fitting into the tank then fitted the small piece of fuel pipe and then the valve.
MikeR
posted on 10/12/05 at 05:51 PM Reply With Quote
Pat...
No Pat, this is everything to do with being in an accident. You need a vent in your tank to stop the vacum. What i'm saying is make sure your vent is safe. Think not just for stopping the vacum but when you're in an accident. Those with lines that run up to the roll bar and back down are not safe! What i'm doing is fitting a vent from stoneleigh. Its not perfect as its going to be attached via a small rubber tube which should (hopefully) be fireproof.
I find it strange but the rules on building road cars are now more strict than race cars in many areas. This is one of them.
Avoneer
posted on 10/12/05 at 08:52 PM Reply With Quote
Sorry mate, thought you were just on about the ones that are for roll over protection only.
Guess I'll order a posh "think" one - can't go wrong then.
Pat...
Kowalski
posted on 10/12/05 at 11:45 PM Reply With Quote
The breather that some cars have has no valve in it. It consists of a length of hose that goes from the top of the tank (where it connects to the tank) down to the bottom of the tank and under it then back up to the top where it's open, sort of in a big 'U'. It has to be designed so that no matter which way up the tank and breather are, the fuel can't run out of the breather.
[Edited on 10/12/05 by Kowalski]
MikeR
posted on 11/12/05 at 01:26 AM Reply With Quote
again this is where my mate chimes in ....... and what are you using to create this big u? Rubber? Pah, lasts about 3 seconds in a fire....... then fuel will wee all over you.
(he's given me this lecture more than once)
p.s. sorry i was a little condensending in my last post - was rushing to get out.
907
posted on 11/12/05 at 06:42 AM Reply With Quote
I have a pipe that runs from the top of the fuel tank to the air filters.
Any good?
Production cars seem to vent all sorts into the airbox.
Paul G
Viper
posted on 11/12/05 at 09:45 AM Reply With Quote
So how quickly would the plasic fuel pipe running the full length of millions of cars take to burn through?
MikeR
posted on 11/12/05 at 12:21 PM Reply With Quote
most cars now use plastic covered aliuminium with reinforced, plastic fireproof overbraid flexi connectors.
I've got 5 lines from the BMW mini in my garage - ex display and heading for the skip!
(edited to add, my mates company does plastic covered Ali, no idea what other suppliers use. Was going to mention companies he works with but don't want to get him in trouble in case i accidentally give away trade secrets)
[Edited on 11/12/05 by MikeR]
ady8077
posted on 11/12/05 at 01:46 PM Reply With Quote
Hi
I used a one way breather valve from https://www.harris-performance.com/website/frameset2.htm
Adrian Rescued attachment breather
<<  1    2  >>
