loco spaniard
posted on 13/12/05 at 03:21 PM |
Hiss system,help PLEASE
Hello all, I am new to the forum,I have a question that I hope I can get a positive answer;
I bought an ECU,receiver and keys (hiss system) for my 929rr fireblade engine...
Tried, cranking over and no spark,also tried with another loom and the problem persist, been told the problem is that the ECU does not recognise the
key,but that's not all, I can't find the invoice....
Does anybody knows of any way to make it work?
Thanks in advance
Braulio
zzrpowerd-locost
posted on 13/12/05 at 03:24 PM |
Ask in the BEC section of do a search for HISS!
Think you can bypass it with a resistor somehow! ![](/images//smilies/bigsmile.gif)
the_fbi
posted on 13/12/05 at 08:49 PM |
See page 2
http://www.mkindy.com/misc/Fireblade_Tech_Tips_Wiring_the_Fireblade_engine.pdf
Also, there is a neutral switch which will need sorting out. It won't spark if in gear, afaik.
Also, there is a tilt switch, which will cut the engine if the bike has fallen over. I guess this will either need wiring out of the loom, or to be
fitted and the correct way up.
[Edited on 13/12/05 by the_fbi]
scotlad
posted on 14/12/05 at 08:41 AM |
welcome to the madhouse Braulio!![](/images//smilies/bigsmile.gif)
loco spaniard
posted on 14/12/05 at 01:51 PM |
Hiss system
Hy guys thanks for your help, I'll try the BEC, I took care of the side stand,clutch sensor ....
I am downloading the information you send
thank you all and Happy Christmas
