Author: Subject: Nitrogen in road tyres
Jasper
posted on 15/12/05 at 01:57 PM Reply With Quote
So, is is b*lloxs, or worth doing, your opinions please:
http://uniflate.com/
Seems reasobale at £6 a car and they've got a depot up the road.....
zzrpowerd-locost
posted on 15/12/05 at 02:01 PM Reply With Quote
well if its good enough for F1.....
greggors84
posted on 15/12/05 at 02:02 PM Reply With Quote
Most of the benfits they talk about are just due to correctly inflated tyres. If the nitrogen really does stay in the tyres better then I guess it could be worth it.
If not just keep your tyres pumped up.
Chris
The Magnificent 7!
bob
posted on 15/12/05 at 02:13 PM Reply With Quote
I think i'll check my pressures once a month and spend £6 on a breckie at our meet
Mix
posted on 15/12/05 at 02:43 PM Reply With Quote
If, as they say the free oxygen etc escapes through the tyre, then the tyre itself is your own personal nitrogen enrichment device. Each time you top up the pressure the ratio of nitrogen to other constituents increases.
Check your tyre pressures more often and put £3 in a safe place each time you do.
This will save you £3 every time you pump up your tyres, give you better tyre life and roadholding, and provide a nest egg for that next 'essential' for the car.
Mick
iceman26
posted on 15/12/05 at 06:12 PM Reply With Quote
i have used it in my bmw and worked well if you drive hard on a and b roads made car handle lot better
bigandy
posted on 15/12/05 at 08:12 PM Reply With Quote
I painted a stripe down my Mini, and that made it handle better on the B roads too.... Maybe in conjunction with nitrogen in the tyres, I would be unbeatable?
Dammit! Too many decisions....
chriscook
posted on 15/12/05 at 08:47 PM Reply With Quote
Where I work we have monitored multple sets of car and commercial tyres over 6 months inflated with normal air and nitrogen. None of them showed any pressure loss. This was a proper test with calibrated pressure transducers fixed into the rims.
Don't know about the other claims
bigandy
posted on 15/12/05 at 09:25 PM Reply With Quote
Personally, I would rather fill my tyres with Helium, and revel in the weight savings!
ed_crouch
posted on 15/12/05 at 09:46 PM Reply With Quote
If you want to be able to get to sainsburys 0.05 seconds quicker, then it sounds like it might be a goer.
Aircraft use nitrogen in the tyres because:
Its not mega expensive (plenty of it around: 78% in the atmos!)
Its basically inert.
Pure Nitrogen has no water vapour in it, which means that the wheel rims/other metallic parts inside the pressure region do not corrode, as there is naff all water around, so no porous rims.
They don't use it for better grip/braking on the runway!! They have s*dding great thrust reversers and aerobrakes for that.
Unless 0.05 seconds really matters, I reckon its a bunch of wally.
Ed.
I-iii-iii-iii-ts ME!
Hurrah.
www.wings-and-wheels.net
Jasper
posted on 16/12/05 at 09:58 AM Reply With Quote
Cheers chaps, so the overiding concensus is it's b*lloxs then .......
And Hicost, yes, of course the car is finished, I'll see you at 'The Pod' on Saturday, don't forget your pink slip
