Author: Subject: Headlamp height ???
Avoneer
posted on 24/12/05 at 12:05 AM Reply With Quote
Headlamp height ???
Anyone know what the bottom of the light should be ???
Was it 400mm from the floor?
Pat...
RazMan
posted on 24/12/05 at 09:19 AM Reply With Quote
The minimum height for dipped beam is 500mm. (There is no minimum for main beam)
Raz
Tigger
posted on 24/12/05 at 09:27 AM Reply With Quote
The maximum headlight height is 1200mm
Take a look at the
1989 Lighting Regulations
HTH
Tigger
[Edited on 24/12/05 by Tigger]
Avoneer
posted on 24/12/05 at 10:44 AM Reply With Quote
Cheers guys.
Sorted my mounts now.
My mount is now 450mm from the floor, but I can raise the suspension for SVA.
Ta,
Pat...
smart51
posted on 24/12/05 at 10:48 AM Reply With Quote
the minimum height is 500 mm from the floor, but this point can be anywhere within the illuminated area of the lens. If the bottom of your lens is 450mm from the ground and the top os 505mm, then you're OK.
RazMan
posted on 24/12/05 at 11:00 AM Reply With Quote
Definitely wrong I'm afraid - 9.1 Note 1 states that the minimum distance is measured at the lowest point of the illuminated area.
Does your suspension jack up by 50mm then Pat?
[Edited on 25-12-05 by RazMan]
Raz
