Author: Subject: Plumbing problem.......
Northy
posted on 27/12/05 at 05:39 PM Reply With Quote
Every time we run the hot tap now after we turn in off the shower pump runs for a fraction of a second. It's the type where the pump is not part of the shower and is next to the hot water tank.
It's just started doing it, anyone any idea why? Is it anything to worry about? #
Graham
mangogrooveworkshop
posted on 27/12/05 at 05:43 PM Reply With Quote
low mains pressure perhaps
Ferg
posted on 27/12/05 at 06:06 PM Reply With Quote
It isn't anything to worry about really. The flow switch is sensing a tremor in the pipe. If you want to stop it fit a check valve at the pump inlet. That normally stops it.
Northy
posted on 27/12/05 at 06:18 PM Reply With Quote
So why has it just started doing it?
Graham
Ferg
posted on 27/12/05 at 06:44 PM Reply With Quote
A few possible reasons. I'ts normally down to the tap setting up a tiny waterhammer in the pipe. Rather like the noise you sometines get with ballvalves, but much smaller. Could be a pipe clip somewhere not holding the pipe as tightly as it did when it was new.....
Northy
posted on 27/12/05 at 08:48 PM Reply With Quote
Nothing to worry about then, cheers.
G
Graham
Northy
posted on 28/12/05 at 10:59 AM Reply With Quote
Just an update, it doesn't do it if you turn the hot taps on or off in the bathroom, or if you turn the hot tap off slowly in the kitvhen. Only if the hot tap in the kitchen is turned off quickly.
Does that sound right? Still nothing to worry about?
Graham
posted on 28/12/05 at 11:07 AM Reply With Quote
Is your shower pump plumbed into the common hot water pipe or is it in just the feed to the shower?
Ferg
posted on 28/12/05 at 12:35 PM Reply With Quote
That certainly sounds like there isn't a dedicated hot to the pump. It's not a problem, but if it annoys you fit a check valve.
Northy
posted on 28/12/05 at 12:42 PM Reply With Quote
Er, I don't know. The previos owner fitted it, how do I tell?
Graham
Northy
posted on 28/12/05 at 12:43 PM Reply With Quote
Don't mean to be thick, but whats a check valve?
Graham
posted on 28/12/05 at 01:18 PM Reply With Quote
When I installed the pump for our shower it was plumbed into the pipe that only fed the shower. It's possible ? that yours is plumbed into the pipe that feeds all of the hot taps ? which could explain your problem, but I could be talking a load of bovine excrement as I'm not a plumber
Ferg
posted on 28/12/05 at 03:30 PM Reply With Quote
Any shower ought to be plumbed with a dedicated hot and cold to avoid fluctuation of flow. However, in practice so long as the cold is dedicated and not serving any other outlet it's acceptable. What you REALLY don't want is a commoned cold...then if someone uses the cold elsewhere you remove some skin from your body.....
A check valve is just a sprung loaded non-return valve that can be fitted on the inlet to the pump. It isolates the flowswitch on the pump from water tremors and prevents annoying false start-ups.
