Author: Subject: Tool to form lip on coolant pipes
posted on 4/1/06 at 02:46 PM Reply With Quote
Does anyone know either who sells these, or what the offical name for them is so I can search?
This is a tool that can form a raised lip on thin wall tubing such as that used in cooling systems, to prevent a rubber pipe slipping off when secure with a jubilee clip etc. I've seen a picture of one ages ago, so I'm sure these do exist (and not just in my imagination!).
Mike S
posted on 4/1/06 at 03:11 PM Reply With Quote
The ones that I have seen are in the Frost catalogue.
They call them Bead Form Tools.
Very nice but quite expensive (£400 ish), so only really an option if you are doing loads of them.
www.frost.co.uk
Alternatively, Car Builder Solutions will make them up for you.
Regards
Mike
There are more horses' asses in this world than there are horses
Just to answer myself they are called "tube beading tools" and they are very, very expensive.
A locost method is to modify the jaws of a pair of vice grips to put a groove in one and a matching lip on the other.
zxrlocost
posted on 4/1/06 at 03:12 PM Reply With Quote
pop rivet the end of the pipe
hey presto
cidersurfer
posted on 4/1/06 at 03:36 PM Reply With Quote
As zxrlocost says rivets work a treat
shimming solid lifters is a job for a friend...
Wadders
posted on 4/1/06 at 03:45 PM Reply With Quote
I think Rorty's bead roller plans include dies for
beading tube.
http://www.rorty-design.com/content/bead_roller_plans.htm
Terrapin_racing
posted on 4/1/06 at 03:51 PM Reply With Quote
Earls tubing supplies in Uk do some cost effective tools to bead piping. I have one and it is excellent.
http://www.earls.co.uk
[Edited on 4/1/06 by Terrapin_racing]
[Edited on 4/1/06 by Terrapin_racing] Rescued attachment 00tube.jpg
posted on 4/1/06 at 03:52 PM Reply With Quote
Wasn't there a post on here a year or so ago about a home made beading tool ?
Terrapin_racing
posted on 4/1/06 at 03:56 PM Reply With Quote
and further details from Earls catalogue
I have used very successfully on mild steel tube also
[Edited on 4/1/06 by Terrapin_racing] Rescued attachment 00tube1.jpg
MkIndy7
posted on 4/1/06 at 04:12 PM Reply With Quote
If its copper pipe, solder a socket on the end
DaveFJ
posted on 4/1/06 at 04:34 PM Reply With Quote
IIRC someone suggested using a pair of mole grips....
weld a bead along the lower jaw and file a matching chunk out of the upper jaw. then just 'crimp' the pipe in stages all the way round.....
Dave
Volvorsport
posted on 4/1/06 at 07:11 PM Reply With Quote
you could do what this turbobricker did !!
http://forums.turbobricks.com/showthread.php?t=58790&highlight=bead+maker
www.dbsmotorsport.co.uk
getting dirty under a bus
MikeR
Contributor
Posts 8600
Registered 25/5/02
Location Hinckley
Member Is Offline
Photo Archive Go!
Building: Slowcost since 2000, speeduino since 2020, Caterha
posted on 4/1/06 at 07:57 PM Reply With Quote
or you could contact allyfab, bryn is a great bloke with great prices and good service.
(yeah, i'm a happy customer)
RazMan
posted on 4/1/06 at 08:55 PM Reply With Quote
A tip I picked up is to anneal the pipe first to reduce risk of cracking.
Molegrip dodge sounds feasable and I might try that.
Apparently you can get the same security by flaring the end out gradually with a small open ended spanner - not as pretty though.
Raz
givemethebighammer
posted on 4/1/06 at 09:35 PM Reply With Quote
I did mine this way
http://www.locostbuilders.co.uk/viewthread.php?tid=14691
DaveFJ
posted on 5/1/06 at 10:09 AM Reply With Quote
excellent solution volvosport....
for those to lazy to follow the link......
surely one of our enterprising chaps on here could start knocking out the wheels on a lathe ? I'm sure they would sell....
Dave
posted on 5/1/06 at 10:40 AM Reply With Quote
clearly the two rollers are brought closer together by doing up the vice but how are they held to the vice jaws?
Now this has got me thinking - for those without a lathe, how about using some large penny washers with smaller ones for the recess welded to each other?
RazMan
posted on 5/1/06 at 10:44 AM Reply With Quote
Drilled and tapped into the sides of the jaws or maybe welded?
Raz
posted on 5/1/06 at 05:10 PM Reply With Quote
Might be worth using a couple ol lengths of angle iron to fit in vice jaws with a plate welded on the end drilled and tapped to take the bolts . quick and easy to fit into place . Think i'll try it out tomorrow if I get time.
