Author: Subject: Wideband Lambda Sensor
jambojeef
posted on 11/1/06 at 10:44 AM Reply With Quote
Am looking at getting a wideband lambda sensor.
I want to use it to check ignition and fuelling so I dont melt my piston crowns on the way to the SVA centre!
Post xmas im not exactly feeling flush but have seen the link below.
http://www.innovatemotorsports.com/products/lc1.php
Anyone any experience? Im guessing you'd have to drive with mixed throttle openings and loads / speeds whilst looking at the gauge and/or log the data somehow - anyone any advice or experience of using one of these?
Geoff
garage19
posted on 11/1/06 at 12:16 PM Reply With Quote
I have the innovate LM1 and it is a superb bit of kit.
Highly recommend the innovate wideband products.
How is the turbo kit for the CBR engine coming on?
jimgiblett
posted on 11/1/06 at 12:19 PM Reply With Quote
My interpretation of the LC1 is that it is a contoller with loop back to your 3rd party ecu to control fuelling.
What I think you are looking for is a meter to tell you your fuelling ratio. The offerings on the link to LM-1 units look fairly good albeit without a dash mounted meter.
The unit I may purchase is here and slightly cheaper too.
CairB
posted on 11/1/06 at 12:37 PM Reply With Quote
Geoff,
I have an LC1 hooked up to a megasquirt.
I use the megasquirt data logging facility but I think that you get an application with the system, never used it though.
See http://www.locostbuilders.co.uk/viewthread.php?tid=27908
I don't think that you should be worrying about AFR on your way to SVA though
Colin
garage19
posted on 11/1/06 at 01:10 PM Reply With Quote
[quoteI don't think that you should be worrying about AFR on your way to SVA though
You should always be worrying about your AFR with a turbo charged bike engine!
ned
posted on 11/1/06 at 01:28 PM Reply With Quote
on our 240bhp vauxhall xe racecar (runningon carbs) we use one of these:
http://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=MSPORT&pcode=R/PDTM4007
don't know if thats of any help though I'm afraid!
Ned.
beware, I've got yellow skin
Volvorsport
posted on 11/1/06 at 01:42 PM Reply With Quote
you can buy just the gauge to show the afrs or the whole thing - ive got the whole thing , and nifty bit of kit it is too
www.dbsmotorsport.co.uk
getting dirty under a bus
stevebubs
posted on 11/1/06 at 03:54 PM Reply With Quote
Give Bill Shurvinton a shout - he can supply a suitable unit for very reasonable cost....
stevebubs
posted on 11/1/06 at 05:37 PM Reply With Quote
Ned.
By the look of it, that just uses a Narrowband sensor...so only really useful for telling you "rich / ok / lean" not "lamba is 19.8"
stevebubs
posted on 11/1/06 at 05:38 PM Reply With Quote
Jim,
If you're interested in taking a look, I've still got one of Bill's LM-1s here
Stephen
jambojeef
Wow, thanks for the replies - good to know its a goodun.
Who's Bill Shurvington steve?!
If anyone's got any tips about setting up carbs for boost using one of these sensors your pearls of wisdom are very much welcome - otherwise a long process of trial and error will no doubt reveal the way to do it!
Geoff
stevebubs
posted on 11/1/06 at 05:44 PM Reply With Quote
Originally posted by jambojeef
Geoff
He's a UK Megasquirt supplier / expert - often found on the se7ens.net list and megasquirt forums...
He also stocks a line in the techedge and innovate products...
Will u2u his details across..
jimgiblett
posted on 11/1/06 at 05:50 PM Reply With Quote
Jim,
Stephen
Very interested indeed I'll give you a bell later (you still on the same mob number from LM 2004?)
Jim
stevebubs
posted on 11/1/06 at 05:53 PM Reply With Quote
Jim,
Stephen
Jim
yup
stevebubs
posted on 11/1/06 at 06:10 PM Reply With Quote
Link to Fuel Fiddler Script
