Author: Subject: 1" nb steel pipe
timf
posted on 11/1/06 at 01:07 PM Reply With Quote
1" nb steel pipe
anyone know where i can get 1" nominal bore steel pipe from i need about 2m of the stuff.
Cheers Tim
Kissy
posted on 11/1/06 at 02:44 PM Reply With Quote
What sort of function, quality and accuracy are you after? I'd suggest 1.25" o.d. with 1/8" wall thickness, ERW if cheap needed, go for cold-drawn seamless if you need a bit stronger + smoother bore.
Guess you may be obliged to take a metric equivalent, 32mm o.d. with 3mm wall.
bigdaddyadd
posted on 11/1/06 at 03:43 PM Reply With Quote
I can get you 1" nominal bore sch40 316l stainless steel. What is it for?
