Author: Subject: Paddle Shift
richijenkin
posted on 6/2/06 at 03:55 PM Reply With Quote
Paddle Shift
The 'lath master' at work knocked this up for me. All I need now is the 6mm alloy. Anyone know of a source? Rescued attachment Paddles.jpg
zxrlocost
posted on 6/2/06 at 04:16 PM Reply With Quote
Metal supermarket in west brom
have to search yell
£34? for 2x2 ft of 6mm alloy
chris
zxrlocost
posted on 6/2/06 at 04:19 PM Reply With Quote
I could do with one of them aswell rich
wanna work something out
Gav
posted on 6/2/06 at 04:24 PM Reply With Quote
umm group buy?
tks
posted on 6/2/06 at 09:12 PM Reply With Quote
mhh
i would laser 3 of them of 2mm alloy and just weld it together with small tig welds..
will be cheaper because 2mm is more common then 6mm sheet..
sow you could easyly find more "unused" pieces.
ChrisGamlin
posted on 6/2/06 at 10:11 PM Reply With Quote
If you put a tab above and below the centre hole and bent these over 90°, could you not incorporate your pivot points into the design, or are you going to be welding those on seperately?
OX
posted on 6/2/06 at 10:53 PM Reply With Quote
i got you a piece of alloy sheet today rich 2x2 £15,an off cut.i think you should be able to sqeeze 3 out of it.
ask your man about the carbon one pls dude .
chris g ,the rose joints bolt up to the paddle and then bolt straight to the piece of alloy he's had made to fit the steering column
zxrlocost
posted on 7/2/06 at 09:11 AM Reply With Quote
carbon one
richijenkin
posted on 7/2/06 at 01:01 PM Reply With Quote
ok, Offers are now being made for the last paddle!!! be quick. If I can get hold a a camera, I'll take a pic.
richijenkin
posted on 7/2/06 at 02:40 PM Reply With Quote
Paddle v2
Heres version 2:
http://www.richijenkin.co.uk/Paddles.EDRW
Side arms are now wider and the corners have a bigger radius. Designed to work with a 300mm steering wheel.
You'll need 'edrawings viewer' (free) to see it, from here:
http://www.solidworks.com/pages/programs/eDrawings/e2_register.html
richijenkin
posted on 27/2/06 at 09:59 AM Reply With Quote
Its fitted...wooohoo:
http://locostbuilders.co.uk/photos.php?action=showphoto&photo=day22.JPG
[Edited on 27/2/06 by richijenkin]
