Baz Kirmy
posted on 7/2/06 at 11:38 AM |
Mushrooms and balljoints
I'm having a problem with mushrooms: the length of the upper ball joint thread seems too short for my GTS mushrooms. When I put the taper in,
the nyloc doesn't actually seem to lock - the top of the mushroom just seems too thick. Do I have to adjust the mushroom in any way? Or get an
upper ball joint with a longer thread?
baz
muzchap
posted on 7/2/06 at 11:58 AM |
What upper balljoint are you using? Probably best if you use the same one that GTS supply via their website - then its guaranteed to fit
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
Danozeman
posted on 7/2/06 at 02:43 PM |
Have u tried tightening it all the way up? It could be that the taper isnt properly home in the mushroom.
Dan
posted on 7/2/06 at 05:19 PM |
IIRC there are two commonly used upper ball joints, the transit TRE and the transit draglink. I seem to recall that they are different lengths but
same taper.
