rabiddog
posted on 14/2/06 at 09:45 PM |
Reliant Scimitar Axle
Anyone know how these comare with an escort axle dimensions and stud spacings?
Craig
Mmmmmmmm......beer....aaaaarrrrrggggghhh
gary gsx
posted on 14/2/06 at 09:49 PM |
Didnt they use capri axles??? may be wrong ![](/images//smilies/smile.gif)
Mike R-F
posted on 14/2/06 at 10:03 PM |
Certainly are (wrong, that is)! The Scimitar unit was unique to the car. As I happen to have both sitting in my workshop, I'll check tomorrow
Mike R-F
posted on 14/2/06 at 10:04 PM |
Stud spacing is same as Truimph BTW. Not sure if this is same as ford but I'll check that too.
jimmyjoebob
posted on 14/2/06 at 10:13 PM |
Scimitar has salisbury diff (as used by jaguar). These are good for large hp (see www.v8church.co.uk).
Axle features better location thanks to watts linkage and parallel trailing arms with damper/spring units whereas capri uses cart springs, panhard rod
and damper struts.
If at first you don't succeed, hide all evidence you ever tried!
gary gsx
posted on 14/2/06 at 10:27 PM |
Well blimey you learn sumin everyday
posted on 15/2/06 at 08:45 AM |
istr it is a modified Salsbury unit not dis-similar to the MGB --- 4 on 4.5" PCD with big wheel studs 1/2" unf I think to match TR 6
front hubs.
[Edited on 15/2/06 by britishtrident]
posted on 15/2/06 at 08:47 AM |
and damper struts.
Panhard rod on a Capri --- the 70s capri cowboys weren't that lucky --- just two extra upper links as per MK2 Lotus Cortina
