omega0684
posted on 26/2/06 at 10:19 AM |
bearing change
morning all, how do i know if the bearings in the hubs need changing?
Alex
stevec
posted on 26/2/06 at 10:30 AM |
If they have play or rough or or noisey when you rotate them.
omega0684
posted on 26/2/06 at 10:33 AM |
is it ok to put the entire upright including the hub into the sandblaster, will the sand effect the bearing, or is the bearing a sealed unit
miserableoldgit
posted on 26/2/06 at 10:37 AM |
In extreame cases wheel will fall off
Jack up one side and rock wheel vertically and then horizontally. Anything more than just a hint of movement and the bearings are loose. Retighten,
if still bad they is bu$$ered
Youth and vitality are wasted on the young
flak monkey
posted on 26/2/06 at 10:38 AM |
Sand will muck the bearings right up
I put new bearings in my hubs regardless, they arent that expensive, and once they are done they should last years.
Sera
http://www.motosera.com
