westf27
posted on 2/3/06 at 05:12 PM |
Windscreen marking
Had my glass cut for the windscreen 6mm laminated.The BS6206 marking was silk screen applied with a pink etching solution.Is that acceptable for Mr
SVA
Chippy
posted on 2/3/06 at 05:42 PM |
Recently did the same, and as I couldn't find a firm locally that could do the correct BS, (but could do BS6206), I contacted SVA, and was told
by a very rude chap, that ONLY the stated BS was acceptable, ie BS857 or BS857/2. Had a hell of a job finding a firm that actualy did it, miles away,
and very expensive. Sorry this is not much help to you, but if the guy was correct, and I can only assume he was, then your piece of glass is no
good.![](/images//smilies/sad.gif) ![](/images//smilies/sad.gif)
keith2lp
posted on 7/3/06 at 01:14 PM |
Windscreen
Hi
My car failed with BS6206 markings this is the bs spec for patio doors / shower screens etc. You will need it marked to BS857/ BS857/2 to pass. I
managed to get one cut for £90.
Keith
