athoirs
posted on 5/3/06 at 07:45 PM |
Zx12r sump mods
Couple of photos of my sump now it has been chopped by my cousin.. took two months for him to do but all it cost was a bottle of whisky!
got a windage plate as well and going to fit an accusump for good measure fitted directly to the oil gallery where the pressure switch is fitted..
this is quite large bore and on the right side of the pump.
![](/galpreviews/a334716-P1010058.JPG) ![Rescued attachment P1010058.JPG](/gallery/a334716-P1010058.JPG) Rescued attachment P1010058.JPG
athoirs
posted on 5/3/06 at 07:46 PM |
another
![](/galpreviews/a334718-P1010059.JPG) ![Rescued attachment P1010059.JPG](/gallery/a334718-P1010059.JPG) Rescued attachment P1010059.JPG
GEORGE80
posted on 5/3/06 at 08:10 PM |
hey andy
got your zx engine then,
i should be wizzing round with that fazer engine you sold me by the end of this month, buzzing i can't wait
posted on 5/3/06 at 09:43 PM |
Sump looks almost identical to ours. Are you gonna fit baffle plates?
Phil
athoirs
posted on 5/3/06 at 10:09 PM |
Hi George.
Hope it all goes ok.. as i said any problems give me a ring or e-mail... somtimes wish I had just kept the fazer as am not sure that this engine is
the best.. have had a lot of problems with it.
Phil - yes a straight copy from your photos! no point re-inventing things!
![](/galpreviews/a334796-P1010060.JPG) ![Rescued attachment P1010060.JPG](/gallery/a334796-P1010060.JPG) Rescued attachment P1010060.JPG
posted on 5/3/06 at 10:59 PM |
Andy, before you bolt the sump back on, it's definitely worth checking that the mating face hasn't warped ever so slightly through the
heat of welding.
Phil
carlgeldard
posted on 6/3/06 at 07:54 AM |
How deep is your sump. I was going to do mine this weekend. Am I right in thinking that I have to cut it off just below the refenforcment ribs.
Carl
athoirs
posted on 6/3/06 at 12:41 PM |
80mm from sump top face to cut.. When he welded it clamped it up to a flat surface but it has still distorted a fraction.. it has tightened up ok
though![](/images//smilies/bigsmile.gif)
posted on 6/3/06 at 06:42 PM |
Ours bolted up OK at first but after a bit of use developed a small leak. To remedy, we removed the sump and used some grinding paste on a sheet of
glass to grind the sump mating face flat. Took an hour or so to do but turned out great.
Phil
carlgeldard
posted on 6/3/06 at 06:50 PM |
Great tip!!!!!!!!!!! I just need to remove the kitchen window.
Carl![](/images//smilies/bigsmile.gif)
GEORGE80
posted on 6/3/06 at 07:44 PM |
hope you get it all sorted, i'm sure you will, looking at the job you did with the fazer, fantastic fit and well laid out
posted on 6/3/06 at 07:50 PM |
Carl, leave your kitchen window in. Just tell the missus you're trying to achieve the frosted look in true locost style (If she asks).
You'll have loads of fun watching her trying to polish it out ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
