<<  1    2  >>
Author: Subject: grooved disc groove direction?
ned
posted on 6/3/06 at 04:25 PM Reply With Quote
just about to fit my nice new brakes, which way should the grooves on the grooved discs face? towards the front of the car at the top or towards the back? or does it make little or no difference?
cheers,
Ned.
beware, I've got yellow skin
NS Dev
posted on 6/3/06 at 04:30 PM Reply With Quote
Dunno the technical answer but I'd go for outermost part of the groove forward, so the pad is swept down onto the retaining recess in the caliper. If it's swept upwards I guess it'll be pushing up onto the retaining pins??
donut
posted on 6/3/06 at 04:33 PM Reply With Quote
I had the same prob Ned and the general thought was grooves forward at the top. There should be a sticker on the discs tell you which side it fits????
found this pic of the near side front.
Image deleted by owner
[Edited on 6/3/06 by donut]
ned
posted on 6/3/06 at 04:37 PM Reply With Quote
i was actually just thinking the opposite so that the brake dust would be thrown out from the disc rather than pulled towards the centre. but then i hadn't thought of pressure on the pad pins..
ned
posted on 6/3/06 at 04:44 PM Reply With Quote
andyps
posted on 6/3/06 at 04:56 PM Reply With Quote
I was about to reply that I thought Donut had them the right way round when you posted the instructions which I rememberd using when I fitted them! At least my memory wasn't too bad.
donut
posted on 6/3/06 at 04:57 PM Reply With Quote
Well there ya go! some say that way, some say this way!!!
What a crazy world we live in
I'm buggered if i'm changing mine though!!
posted on 6/3/06 at 05:04 PM Reply With Quote
mine are wrong, to no ill effect
indykid
posted on 6/3/06 at 05:20 PM Reply With Quote
i'm pretty sure ap racing's website says donut's way, and that's why we all went with that at the time.
it can't make that much difference though can it?
tom
Mr G
posted on 6/3/06 at 05:53 PM Reply With Quote
Drivers side the EBC way.
G
posted on 6/3/06 at 06:02 PM Reply With Quote
I thought it was different for the drilled ones to the ones with grooves only.
flak monkey
posted on 6/3/06 at 06:05 PM Reply With Quote
Some say one way, some another.
With them the way EBC say to fit them (outer edge of groove facing up on the front edge of the disc) any crap in the grooves is thrown out. The other way around, the grroves just trap dust and dirt and dont get rid of it. No idea why you want to fit them the other way around to be honest, but I guess I cant argue with the brake manufacturer eh?
Sera
http://www.motosera.com
MkIndy7
posted on 6/3/06 at 06:30 PM Reply With Quote
I thought grooves pointing forward were more agressive and noisier.
After searching Yahoo for images it seems racing cars have the grooves facing forward and road cars facing rearward, maybe this supports the noise and harshness theory?
[Edited on 6/3/06 by MkIndy7]
graememk
posted on 6/3/06 at 06:48 PM Reply With Quote
depends if the groves go to the outside edge or not, if they do its to get rid of water quickly so groves pointing back, if the gove dosnt go to the edge pointing forward to make braking better.
graememk
posted on 6/3/06 at 06:50 PM Reply With Quote
or point them forward to wair them out fast or back slow lol
posted on 6/3/06 at 07:19 PM Reply With Quote
Check the manufacturers recommendations
(If you know who the manufacturer was, of course)
tadltd
posted on 6/3/06 at 07:28 PM Reply With Quote
We recommend that our discs are fitted in the same way as the EBC ones shown (also the same as Ned's instructions) - i.e. make sure the curve is concave in the forward direction.
Ned - you have a U2U (ref' SPA gauge)...
Best Regards,
Steve.
www.turnerautosport.com
jimmyjoebob
posted on 6/3/06 at 08:06 PM Reply With Quote
From the braking assignment carried out a few years ago it shouldn't matter which way around the grooves face from a brake efficiency viewpoint.
Dust build up is unlikely to have been considered important to direction - the speed of airflow is likely to dislodge any particles before buildup occurs. That is unless it hasn't been shaken out along with my fillings by the constant thudding of the wheels on every pothole in this god-forsaken road network of ours....
The grooves merely allow the gas that the pad material releases when overheating to escape, preventing it from acting as a cushion between pad and disc - otherwise known as brake fade.
If at first you don't succeed, hide all evidence you ever tried!
Alfa145
posted on 6/3/06 at 08:28 PM Reply With Quote
These are my RedDot 6 Groove fitted the way the instructions said, I had a few people query why they are fitted that way and ended up asking RedDot if it was correct and they said it was, but their 20 & 40 groove ones fit the other way. I guess most manufactures have their own way and reasons
(the front of the car is on the left)
Fozzie
posted on 6/3/06 at 09:15 PM Reply With Quote
Ned, opposite way to Andy-mates (aka donut)!
Fozzie
ned
posted on 6/3/06 at 10:39 PM Reply With Quote
well, while everyone has been debating it i have fitted them all Rescued attachment IMG_1860b.jpg
ned
posted on 6/3/06 at 10:42 PM Reply With Quote
MkIndy7
posted on 6/3/06 at 10:45 PM Reply With Quote
Another spanner to throw into the equation.
It might be to do with the shape and number of the grooves cut in the disk as to which way around there to be used.
I've got 36 square cut grooves going the opposite way to those last pictured (alfa147's) but they are rather "noisy" i.e you do hear a slight grating noise as they are applied lightly.
On the kit car we've got (probably 18) grooves going the same way but with rounded edges (like greenstuffs) cut with a ball end cutter and theres no extra noise at all compared to standard.
I'd hate to think the 36 groove versions would make and more noise if the grooves went the other way.
NS Dev
posted on 7/3/06 at 09:14 AM Reply With Quote
Going back to my point about pad retention...........................
If the brakes make a "grating" or slight vibration under light braking, then the pads are vibrating.
If they are, then they want to be pushing the pad against an abutment if there is one.
Now different calipers support the pad in different places.
Those with std sierra calipers can do what they like cos the pad is totally supported on abutments, but on my RaceLeda calipers, the abutments are on the "hub side" of the caliper, nearest the disc centre, hence "pulling" the pad inwards.
Looking at your Hi-Spec calipers Ned, they don't look like they have abutments at all, so I guess it doesn't matter!
MkIndy7
posted on 7/3/06 at 04:50 PM Reply With Quote
Not to discount this info completely but my 36 groove disks with the square edeges are on Sierra calipers and still make a grating noise.
<<  1    2  >>
