16vmini
posted on 7/3/06 at 06:19 PM |
Digital Dash , group buy !
sorry new on here , but thought you guys might be intrested in cheap digital dashes from acewell ,
i run the 16v mini club , check out the group by thread on our site :
http://www.16vminiclub.com/forums/viewtopic.php?t=5148&postdays=0&postorder=asc&start=0
can do the above dash for 99 pounds to your door.
Matt
craig1410
posted on 7/3/06 at 06:36 PM |
Hi Matt,
I am very interested in a 3853 model but I need to know if it will work on an 8 cylinder Rover V8 engine. I couldn't see anything on the website
at first glance which would confirm this - do you know if it will work?
Also, can you please confirm exactly what is or is not supplied. I believe from the website that you get the dash, a loom and a speed sensor and
magnet kit. Is that correct?
I also understand it to be SVA compliant which is obviously very important for us Locost'ers.
If you can confirm it will work on a V8 then I think I will most probably have one (via Paypal).
Craig.
16vmini
posted on 7/3/06 at 06:39 PM |
quote: Originally posted by craig1410
Hi Matt,
Craig.
from what the supplier told me , it is SVA compliant, also you are right in what it includes.
i will find out tommorow if it works on v8 engines , is yours carb or injection ? as some ecu's have a rpm output.
Matt
flak monkey
posted on 7/3/06 at 06:41 PM |
Craig,
I bought one of the lower models a few months ago now.
You get the dash and all the wiring you need and a speed sensor as well. You need to supply your own fuel gauge sender though (standard 100ohm one
IIRC).
Its SVA compliant as its backlit and keeps a record of total mileage which cannot be reset. Its also E marked on the back, not that that probably
means a thing.
As for what tacho signals it will work with, mine has adjustment for 0.5, 1, 2 and 3 engine rotations per pulse.
See here for the instruction manual:
http://www.acewell-meter.com/images/ACE-37-38XX-EN-V4%20manual.pdf
[Edited on 7/3/06 by flak monkey]
Sera
http://www.motosera.com
16vmini
posted on 7/3/06 at 06:43 PM |
what s your view on them david ? install go ok ?
Matt
Aboardman
posted on 7/3/06 at 06:45 PM |
may be intrested for the mini i am restorting.
hope you do not mind i put the link on the minifinity site as somebody has been asking about digital dashes recently.
what is closing date for offer?
[Edited on 7/3/06 by Aboardman]
16vmini
posted on 7/3/06 at 06:46 PM |
not a problem , more the merry ! lol
Matt
flak monkey
posted on 7/3/06 at 06:48 PM |
Matt
Well I havent got it in my car yet, but i rigged it up to a battery and its a nice bit of kit. Had a fiddle with all the settings which is a doddle.
The backlight is permanently on and bright, without being dazzling. The refresh rate on the speed is pretty quick as well, certainly an improvement
over a normal bicycle speedo.
I would recommend them anyway.
I know there a few people on here who have actually got them installed on their cars, and on the road with them.
Sera
16vmini
posted on 7/3/06 at 06:50 PM |
cheers , thats good to know , as i have just convinced lots of people to buy one ! lol
Matt
TPG
posted on 7/3/06 at 06:55 PM |
U2U
Matt.I've u2u'd you about a 3853 but reading the link theres the 3150 without the warning lights,that you can get....It'll be one of
these instead please.Thanks.
..Which was nice..
theconrodkid
posted on 7/3/06 at 07:28 PM |
what you peeps think about the 2853?
who cares who wins
pass the pork pies
flak monkey
posted on 7/3/06 at 07:32 PM |
You want the 2851 if you want a 2 series one. Unless you need a neutral warning light for a bike engine!
I think the round ones are more suited to bikes and quads myself, but each to their own
Sera
craig1410
posted on 7/3/06 at 07:34 PM |
David,
Thanks for the link to the user manual I think I am correct in saying that it should work on a V8 although I would appreciate someone confirming my
logic:
V8 engine fires the ignition coil 8 times every 2 revolutions therefore 4 pulses per revolution (at the coil). That would rule out connecting the ACE
dash directly to my coil as I would need the option to have 0.25 revolutions per pulse and 0.5 is the minimum.
However, each spark plug on the V8 fires only once every two revolutions (like most multicylinder engines) and so if I connect the ACE dash to one of
the spark plug leads as shown in the manual then it should work fine.
Correct?
Craig.
COREdevelopments
posted on 7/3/06 at 07:43 PM |
hey 16vmini. when do you need the payment by as i am bit short at the mo. just bought a R1 clock hoping to get that set up, but now saw the one you
selling and it looks simpler.
16vmini
posted on 7/3/06 at 07:57 PM |
well at this rate i may place two bulk orders , i have a few others who dont get paid till the end of the month ... otherwise i may just order a extra
couple and hope i can sell them later
Matt
16vmini
posted on 7/3/06 at 08:04 PM |
quote: However, each spark plug on the V8 fires only once every two revolutions (like most multicylinder engines) and so if I connect the ACE dash
to one of the spark plug leads as shown in the manual then it should work fine.
Correct?
Craig.
sounds good to me , allready have a order for someone who has a v8 , so i assume he has checked as well
Matt
gary gsx
posted on 7/3/06 at 08:42 PM |
Has any one got dimensions
the_fbi
posted on 7/3/06 at 09:55 PM |
I'll take a 3853 too. PayPal on its way
COREdevelopments
posted on 7/3/06 at 10:38 PM |
gary dimentions are 125 x 78 x28.5 mm
thats what it says on the acewell webpage http://www.acewell-meter.com/
craig1410
posted on 7/3/06 at 10:39 PM |
Hi Matt,
Okay I've sent you a paypal payment for £105 for a 3853 and will U2U you the reference number so you can match the payment up with me here.
Thanks,
Craig.
tom court
posted on 7/3/06 at 11:08 PM |
digi dash
got mine fitted at weekend will post som pic when i have time. looks cool
omega0684
posted on 8/3/06 at 01:33 AM |
i take it that, if you install this then you dont need to have a bright 6 module?
flak monkey
posted on 8/3/06 at 07:38 AM |
You still need some warning lights that arent on that dash, namely a brake fluid level warning light, and an alternator/charge warning light. Hence
why I went for a simpler dash with seperate warning lights (a bright 6 infact), cost about the same in the end. You can buy individual warning lights
with the correct symbols on for about £3 each from people like VWP to add the missing ones.
Each to their own though
[Edited on 8/3/06 by flak monkey]
Sera
ch1ll1
posted on 8/3/06 at 12:53 PM |
THEY ARE VERY GOOD
bought one about 6months ago
ideal for most engines
and very easy to wire up !
ch1ll1
posted on 8/3/06 at 12:54 PM |
THEY ARE VERY GOOD
