Author: Subject: Jenvey problem
Markp
posted on 12/3/06 at 05:31 PM Reply With Quote
Jenvey problem
I have just received the throttle linkage to go with the raceline jenvey throttle bodies.
Has any one fitted these and had a problem with the clearance between the linkage and the body of the throttle body??
I'm not going to get a file on it as these were too expensive to bodge up.
Any ideas??
mookaloid
posted on 12/3/06 at 05:55 PM Reply With Quote
Just guessing - not tried them myself, but perhaps the arm will go on in a different position say 90 Deg from where you have it?
HTH
Mark
Mix
posted on 12/3/06 at 06:11 PM Reply With Quote
Mine is exactly the same. I plan to shorten the thread and use a half nut secured with thread lock.
Mick
Tigger
posted on 12/3/06 at 06:57 PM Reply With Quote
Will the linkage attach to the arm on the other end.
In other words, can you make it a pull arrangement rather than a push (or vice versa) ??
Tigger
Markp
posted on 12/3/06 at 07:01 PM Reply With Quote
some good suggestions I'll try thank.
Cal vinx - hinesight (spelling) is a wounderful thing, thanks for making me feel better
Mark
