muzchap
posted on 18/3/06 at 11:54 PM |
Inline Fuel Filter - 12mm HELP
Hi guys,
I need to put a fuel filter in between my tank and pump - 12mm tank outlet and 12mm fuel pump inlet.
Therefore I thought a 12mm fuel filter would be the best option.
It needs to be high flow - sounds simple huh!
WRONG
I can't find one.. well I say 'cant' - Demon Thieves want £50+ for one - I don't want the shop - just the f'king
filter
Murray
[Edited on 18/3/06 by muzchap]
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
stevebubs
posted on 19/3/06 at 01:33 AM |
Call Think Auto....they'll mix and match fittings to get what you want.
ned
posted on 19/3/06 at 02:46 AM |
The bullet filter that dt and burtons etc sell is the most commonly available - I've got the fse swirl pot that has a built in filter and 12mm
outlet so gets round the problem that way.
Otherwise as already suggested think auto would be my next move..
Ned.
beware, I've got yellow skin
omega 24 v6
posted on 19/3/06 at 10:26 AM |
What about some of the older v/hall injection filters they had rolled ends for pipes and jubille clip type fittings and must have been around 10 or 12
mm
the_fbi
posted on 19/3/06 at 11:13 AM |
mm
The external pump cav/cally's have 12mm outlets and the filter is external so is 12mm in/out. Its a large beast though.
muzchap
posted on 19/3/06 at 11:18 AM |
Cheers guys - I think I'll give ThinkAuto a call.
Calvin - cheers mate - but I couldn't find them on the site - you got a link?
Omega - yeah I had heard that too - I'll do some investigation - the only prob I have is that the space is tight at the back, so needs to be
quite a small filter...
Cheers guys
muzchap
posted on 19/3/06 at 04:29 PM |
LOL - hmm I discounted it as it was only 10mm :-(
If I get that I need reducers :-(
Might be an option though and thanks for providing the link
NS Dev
posted on 20/3/06 at 08:27 AM |
Had this one a few times mate, three answers. One is just don't bother with a filter on the injection pickup side, most production cars
don't.
Next is the pickup filter from a Manta GTE, these had a very small plastic filter with a washable gauze in it on the pickup side of the pump.
Next is to use the bosch injection pump fitted to "some" peugeot 405 injections (and no doubt some other cars as well) which had an
inbuilt gauze inside the inlet barb)
[Edited on 20/3/06 by NS Dev]
