liam.mccaffrey
posted on 21/3/06 at 01:05 PM |
exhaust collectors
going to do an exhaust for myself 4-2-1, 1.75''-2 1/8''-2.5'' in mild steel but i'm having trouble sourcing
the collectors, milner don't do any mild ones. Any ideas?
Cheers liam
Build Blog
Build Photo Album
timf
posted on 21/3/06 at 01:17 PM |
make your own
form a cone of steel to that the minor dia is your outlet then inlet size can then be hammer formed to size over a former made of steel bar
A prisoner of war is a man who tries to kill you and fails, and then asks you not to kill him."
- Sir Winston S. Churchill, 1952
andylancaster3000
posted on 21/3/06 at 01:28 PM |
Try Jetex:
http://www.jetex.co.uk/website/jetexcustomexhaustparts.php
HTH,
andylancaster3000
posted on 21/3/06 at 01:52 PM |
I believe the Demon tweeks parts are jetex supplied. Dont know what the price differences are though?
NS Dev
posted on 21/3/06 at 01:59 PM |
make em like this, pretty neat and tidy. Easiest way i have found on a DIY basis.
just add that you need to linish the outlet end flat after opening up the split.
[img][/img]
wicket
posted on 21/3/06 at 02:41 PM |
Pipecraft (Lancing, West Susex) are very good, really pleased with what they did for me.
Talk to the production manager Andy Woods on 07961 901580, don't use works phone number.
Not local to Milford haven but the parts you are after are relatively small so post should be reasonable.
A phone call and faxed/e-mailed drawings would probally do the trick.
posted on 21/3/06 at 02:58 PM |
Like Nat's idea
But a bit more work, easy with a holecutter and it hides your weld. Push your tubes through a bit and weld from behind and the shape fits in the top
of your opened out tube and welds in.
