Author: Subject: Off + On road Buggy - GSXR1100 powered
cloudy
posted on 21/3/06 at 02:50 PM Reply With Quote
Just the beginnings of my project log for anyone interested!
The design is completely from scratch - all designed in 3D Studio max. I have no experience in the car building field so my learning curve has been steep so far!
Specs so far:
GSXR 1100cc engine - 155ish hp
Sierra cosworth LSD diff undergoing chain conversion
Aiming for under 350kg's kerb weight
The final 3d design - time to get building!
My current method of tube notching
As you can see it's pretty small when rendered next up next to a 106!
one of the welds from my old arc welder!
parts layed out for size checks
and a render of the body over the beginnings of the chassis (with added air intake, and oil and water cooling ducts
More to come as it progresses!
Hoping to get this on the road at some point, so SVA tips that are obvious issues with my design would be welcomed!
Thanks,
James
G.Man
posted on 21/3/06 at 02:55 PM Reply With Quote
looks cool, would suggest more triangulation if you want it to stay the same shape
Opinions are like backsides..
cloudy
posted on 21/3/06 at 02:56 PM Reply With Quote
yeah will add in afterwards as I can see the outline in front of me, I find it easier estimating forces that way
Deckman001
posted on 21/3/06 at 02:59 PM Reply With Quote
Don't let my son see this topic, he wants me to build a go kart with him, but I would want 1 just like yours !! oh what fun
one day , one day
Jason
NS Dev
posted on 21/3/06 at 03:58 PM Reply With Quote
Right, a subject close to my heart as you know!
This is meant constructively not nit pickingly (as people that know me will say, I am no nit picker!!!)
I would strongly recommend a "redesign" of your chassis in a few areas! There are a couple of areas where you are putting loads into tubes with no support, which is bad, but the worrying one is that your rollbar support does not feed into a triangulated section.
Basically put in the red tubes in the pic below and take out the blue ones, and you'll be nearer the mark.
good luck, looks a real hoot, somehting I would love to do if I only had the time!!!
offroader 1
offroader 1
cloudy
posted on 21/3/06 at 04:16 PM Reply With Quote
thanks, yes I had spotted that roll bar problem, and i'll take those suggestions onboard
btw anyone got a full SVA manual in digital format? just want to check and make sure there's nothing i'm going to do that might make it unpassable
phelpsa
posted on 21/3/06 at 06:07 PM Reply With Quote
Do you have the engine in 3d? If so I couldnt borrow it could I as im using the same engine in my locost.
Adam
cloudy
posted on 22/3/06 at 09:04 AM Reply With Quote
sorry no, the only engine i could find was the v8 busa
it's just a photo of it in that last shot
James
RussH
posted on 5/4/06 at 08:17 AM Reply With Quote
I've been looking around for someone that sells an on-off road buggy with a decent engine for ages so I'm very interested in your project. It's the only thing I'd be tempted to sell my R1 Fury for. I'm more than happy to help where I can. I've also got an SVA manual in PDF format I can send to your email address.
U2U sent
Russ
