Author: Subject: Which cars had the 4AGE engine?
Donuts
posted on 28/3/06 at 12:13 PM Reply With Quote
see subject:
which cars had the 4AGE engine in them?
Fly Like a mouse, Run Like a cushion, Be the small Bookcase
ned
posted on 28/3/06 at 12:14 PM Reply With Quote
old corolla's and mk1 mr2's afaik, someone more knowledgable can probably give exact years and models..
Ned.
beware, I've got yellow skin
rusty
posted on 28/3/06 at 12:19 PM Reply With Quote
Correct, they are in two types of Corolla AE86 (RWD) and AE92 (FWD)
r3nuf
posted on 28/3/06 at 12:58 PM Reply With Quote
Plus Trueno's and Sprinters (Jap only), i think.
Gary
Drive Fast....Brake Late....Take Chances
Prez
posted on 28/3/06 at 01:28 PM Reply With Quote
The earlier Phase 1 and Phase 2 engines can be found in the mr2's and ae86 corrolla. The better (im my opinion) Phase 3 comes from the ae92 corrolla gti
bimbleuk
posted on 28/3/06 at 02:10 PM Reply With Quote
Also the AE82 Corolla. More boxy shape than the later AE92.
COREdevelopments
posted on 28/3/06 at 04:49 PM Reply With Quote
ae82 had early version tvis like mr2. ae92 are the best ones to have as they have stronger block. some early ae92 as in E to F reg had the tvis type ones too. look for a ae92 scrapper as the arches and sill probably dont exist, but the engine should be sound.
locost_bryan
posted on 29/3/06 at 04:30 AM Reply With Quote
All Corolla-derived models (Sprinter/Levin/Trueno)
AE8* 84-87
AE9* 88-91
AE10* 91-94
AE11* 95-00
Check here for full details.
Bryan Miller
Auckland NZ
Bruce McLaren - "Where's my F1 car?"
John Cooper - "In that rack of tubes, son"
Chazzy
posted on 29/3/06 at 08:40 AM Reply With Quote
I agree with all those above, plus i thought i would be good to have a post with as many 4AGE users as possible!
Chas
millenniumtree
posted on 29/3/06 at 08:20 PM Reply With Quote
I'm trying to find a 20v 4A-GE in the states. I know they were never sold here, so I'd have to import it from JDM. Anyone know of a state-sider who has fitted a 20v?
I like the 20v because it's 160hp stock.
Flat Pack
posted on 29/3/06 at 09:41 PM Reply With Quote
I think that 160bhp figure was a bit optimistic on Toyota's part I'm still using one though...
cs3tcr
posted on 29/3/06 at 11:36 PM Reply With Quote
I'm running a 4AG motor in my car. I've got the early 3 rib block, with the later small port head, running 294 duration cams, Mega-Jolt ignition and currently 40 dcoes. But, i'm in the process of swapping the Webers for a set of CBR900 bike carbs.
As for a Locost builder in the US with a 20 valve, Dr. Hess on the locost NA board has been building one.
Rod
tks
posted on 30/3/06 at 12:37 PM Reply With Quote
mhhh
the says this..
DIN = International Standards Organisation.
Well DIN means Duitse Industrie Norm..
it means the German Industrial Norm..
Internat.. Stand Organ.. = ISO
Tks
bimbleuk
posted on 31/3/06 at 07:33 AM Reply With Quote
The Toyota figures are very likely from an engine dyno without the usual anciliaries attached. I've had a lot of them and they tend to read below the quoted figures!
The dyno I use is a Sun eddie current chassis dyno in Cheltenham. Though the figures obtained are usually lower than most others I've seen it regularly measures factory figures from a lot of cars. For example Honda type Rs at 197BHP and my Audi TDi at 89BHP (factory 90BHP).
RAW engineering use this dyno for mapping and they sell a lot of the 20Vs in this country. The average figures for standard engines I've seen are below.
Silvertop 20V 142 BHP @ 7400 RPM
Blacktop 20V 147 BHP @ 7800 RPM
Both engines produce about 110-112 lbs ft of torque with 80-90 % of max torque being produce from 2500 RPM to 7000 RPM.
I mostly see inertia roller dynos used in the US which are fine so long as you only compare like for like. From my observations they tend to give a higher figure than the dynos I've used.
