Author: Subject: Is this swaging
rusty
posted on 29/3/06 at 03:50 PM Reply With Quote
Is this swaging
When you get a tube or pipe with a lip so that when you clip a rubber hose on to it, it will not pull off. Or is this called something else.
Also anyone know wherer to get a too that does this.
DarrenW
posted on 29/3/06 at 03:56 PM Reply With Quote
Frosts do a tool for this but it is not locost (£400 plus).
i got my ali pipes ready flared from mac#1 along with Samco hose for very reasonable price.
iank
posted on 29/3/06 at 03:58 PM Reply With Quote
That's a 'bead' I think (think swaging is bending around a hole in sheet to make it stiffer).
See
http://www.locostbuilders.co.uk/viewthread.php?tid=36828
and
http://www.locostbuilders.co.uk/viewthread.php?tid=36334
The thing made out of a vice is definately the 'lowcost' solution...
BKLOCO
posted on 29/3/06 at 04:28 PM Reply With Quote
I've got one
I made it myself
Similar principal to a knurling tool.
It works best in a lathe but you can use it in a vice.
Photo in archive tomorrow for anyone who fancies making one.
greggors84
posted on 29/3/06 at 04:46 PM Reply With Quote
Easy way to make a tool is get an old pair of pliers, a ball bearing (size depending on the size of the flare you want) and a nut (sized so the ball bearing sits inside it.
Weld or otherwise attach the ball bearing and nut to the pliers one on each side, then put the wall of the pipe in between and squeeze.
Go round the pipe and repeat. If you are using a jubilee clip only four points are probably needed to hold the pipe on.
[Edited on 29/3/2006 by greggors84]
Chris
The Magnificent 7!
planetester
posted on 29/3/06 at 07:42 PM Reply With Quote
It is a bead.
best way for us to do it on 8mm copper tube is to get some 8mm olives from the plumbers merchant & solder them on
[Edited on 29/3/06 by planetester]
