Author: Subject: Megasquirt running , but now i need to set it up.
paulf
posted on 30/3/06 at 10:31 PM Reply With Quote
I have finally got my car running on Megasquirt for fuel and megajolt supplying the sparks.
After some messing around with ve tables it ticks over and revs fairly easily but havent driven it yet. I am planning on taxing it on saturday and then need to set up to be drivable , unfortunately I havent fitted an 02 sensor as i am running LRP fuel addiive so will have to set up by plug readings i think.
Paul.
[Edited on 30/3/06 by paulf]
MikeP
posted on 31/3/06 at 12:50 AM Reply With Quote
Yep, that, but first by ear, then by feel, and finally by stopwatch. Plugs will tell you about mixture during cruising. The tricky part will be trying to set up accel enrichment. Otherwise tuning VE table is really not that different from setting up a carb.
