<<  1    2  >>
Author: Subject: pushrod suspension explained
rv1890
posted on 12/4/06 at 12:09 AM Reply With Quote
Is there a book or a website that explains pushrod front supensions in detail??? I recently purchased Caroll Smiths book "Engineer to Win", and it doesnt really explain pushrod suspensions. I need a book or website that explains the choice of suspension link lengths, attachment point positions, and wishbone angles must be made, along with the layout. I was looking at the book called "Race car vehicle dynamics", but didnt want to buy it unless its going to help. Thanks guys,.
v8kid
posted on 12/4/06 at 06:53 AM Reply With Quote
If thats the book by Milliken and Milleken buy it without doubt its the best suspension book I have ever read.
I'll check my copy tonight to see how much depth it covers push/pull rod suspension
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member   v8kid 's Aim
nitram38
posted on 12/4/06 at 08:39 AM Reply With Quote
Just remember some basic geometry.
Think about pivots (see saws?) and angles. If you make uneven pivots you can increase the effort or decrease the effort depending on which way around they are. Keep angles equal. If the wisbone is 90 degrees to a pivot, make the shock 90 degrees to the pivot.
If it is 45 then make the other 45.
My suspension only moves an inch so the angles are not that critical as long as 1 inch of pushrod movement transfers to 1 inch of shock travel.
[img][/img]
[Edited on 12/4/2006 by nitram38]
rv1890
posted on 12/4/06 at 05:10 PM Reply With Quote
That all sounds great, but where can I find mathematical reasoning behind that???. Lets say for instance I had (2) identical suspensions both setup with 90 degree pivot points as mentioned. If one of the suspensions had a 200 lb spring rate and the other a 150 lb spring rate wouldnt the suspension travel differ.
I guess what Im asking is where are the calculations that explain to me that if I use a "x" lb spring, with a "x" inch length pushrod, mounted at "x" degrees on the pivot point = "x" amount of suspension travel. X being variable depending on the size of my chassis.
Am I asking the wrong thing or is there a book or web site that explains this. Thanks guys
nitram38
posted on 12/4/06 at 05:22 PM Reply With Quote
When you build your car, unless you actually know the finished weight, then calculating spring rates will be the same whether pushrod or normal suspension.
If your pivots are one to one, then the springs will be the same as a normal car with non-pivot suspension.
I built mine with the reasoning that springs can be changed.
I would suggest that you fit a 'dummy' shock in the form of a solid bar until the car is ready or put a shock and guess a spring rate.
Springs are a matter of choice, once you have driven the car.
Unless your car has been built before, then you will probably have to change the springs anyway.
rv1890
posted on 12/4/06 at 06:54 PM Reply With Quote
Ok Nitram, your advice has been very helpful, and Im going to pick your brain a little further.
Your idea about building it with a dummy shock and spring make sense, but what about mounting locations. Some shocks have varying distances between the mounting holes. I myself cant afford the luxury of trying on one spring and then changing to another if it doesnt work properly. I also dont want to to have to reweld mounting locations for the shock sand buy new springs until I find the one I need. What would you suggest here??
Where can I refer to if I want to find the closest spring rate according to the weight of my vehicle and driver. I want to buy the book "race car vehicle dynamics" but dont want to spend the 100 dollars if it does not contain the info. I need.
rv1890
posted on 12/4/06 at 06:58 PM Reply With Quote
You know what??.....after rereading your statements and discussing with a friend of mine it has become more clear what you were saying. You can disregard the last message.
but is that book still what I need??
nitram38
posted on 12/4/06 at 07:06 PM Reply With Quote
I just built mine as I went. I put the pivots in place with tack welds. I then attached a shock and worked out where it would connect to the chassis without binding or hitting everything. Last I attached the pushrods and fixed the pushrod mount on the wishbone.
Things to make your life easy are having the pusrods with left and righthand threads so that you can extend it without removal (like a track-rod end).
Also I bought mounts for the shock that have a welded bush one side and a big hole on the other. They came with a bush that fits in the big hole and a bolt.
When you tighten these, it allows you to centre the rods/shocks easily.
[img][/img]
Liam
posted on 12/4/06 at 11:08 PM Reply With Quote
There's no reason why you should have to guess a spring rate and change it once you've driven the car. You can design your suspension for a natural wheel rate (cycles per minute) of your choice. Pushrods dont have to be any harder to design than normal wishbones or rockers like mine - it's just a matter of calculating how much your shock is going to move compared to how much your wheel moves. Just basic leverage and geometry.
Yes, everything you need is in the super expensive Milliken and Milliken book, but that is very heavy on maths and theory. Really does have absolutely everything related to designing and buildig a race car though. For you I'd recommend the Race And Rally Car Source Book by Allan Staniforth. This deals with the same topics in a much more accesable and practical way, and is as detailed as you really need to design a simple suspension. The RARCSB deals with all aspects of car design - the same author also has a suspension specific book called Competition Car Suspension. Haven't read this myself as the RARCSB contained everything I needed to design my suspension.
Hope that helps,
Liam
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member   Liam 's Aim This User Has MSN Messenger
rv1890
posted on 13/4/06 at 02:07 AM Reply With Quote
Sounds a lot more logical. Ill look into that book and see what I find. Thanks.
chriscook
posted on 13/4/06 at 08:05 AM Reply With Quote
Have you also considered pullrod suspension? The rod can be smaller/lighter as it is always in tension and therefore can't buckle.
Chris
(sorry to to add more confusion)
posted on 13/4/06 at 10:09 AM Reply With Quote
Originally posted by nitram38
Is it safe to load the rod end on the lower wishbone in that way? The weight of the car is trying to pull out the ball in the weakest plane...
nitram38
posted on 13/4/06 at 10:23 AM Reply With Quote
Which rod end are you talking about, the one on the pushrod or the one on the wishbone?
If you are talking about the wishbone one, take a look at a formula renault suspension:
[Edited on 13/4/2006 by nitram38]
posted on 13/4/06 at 11:53 AM Reply With Quote
Do standard gas shock absorbers work horizontally? Years ago we were warned that they would not function properly unless mounted in the correct orientation, i.e. with the top facing upwards and would need different shocks because of the valving.
nitram38
posted on 13/4/06 at 11:58 AM Reply With Quote
I am using GAZ shocks and they work fine, although they are horizontal and slighty tilted down towards the top mounts. They do not leak and operate normally.
wildchild
posted on 13/4/06 at 12:11 PM Reply With Quote
Chris
presumably works with a rod from the outboard end of the top 'bone to somewhere down in the bottom of the car?
chriscook
posted on 13/4/06 at 01:52 PM Reply With Quote
Yes thats right. Puts the dampers down low in the chassis for lower CofG too. But they are less accessable for adjustment..
wildchild
posted on 13/4/06 at 02:12 PM Reply With Quote
interesting.
i'd never really considered using inboard shocks till I read this thread, but it's got some interesting possibilities.
if nothing else it would stop your shocks getting coated in road crud
I might have to have a more serious look at this idea.
Tralfaz
posted on 13/4/06 at 05:47 PM Reply With Quote
That's just the toe link visible, no? Lower wishbone end is hidden behind the drive axle boot
nitram38
posted on 13/4/06 at 06:50 PM Reply With Quote
The picture is off a rear suspension and the other one is a rod end too. The fronts are the same.
You just have to make sure that you buy the right rod ends. There are some cheap ones that cannot withstand high loads.
eddymcclements
posted on 13/4/06 at 09:29 PM Reply With Quote
In the Formula Renault design you've illustrated the rod-end is sandwiched between the casting above and a hefty steel plate below. If the ball pops out of its housing the joint will at least remain captive on the bolt passing through the rod-end while the driver slows down and halts.
Eddy
nitram38
posted on 13/4/06 at 10:17 PM Reply With Quote
Eddy
Impossible to do on front suspension as it is a turning point, but if you could see closer in my photo, you would be able to see a wedge shaped spacer that does the same job.
Also the main reason the sandwich plate is there has more to do with a stud fixing in the aluminium (not a bolt right through) and the bar gives it more strength.
Most formula renault rod ends and captive bearings have copper inserts that break away during a shunt to save the uprights.
There are lots of cars using rod ends in this way.
Check out: http://www.pegasusautoracing.com/productselection.asp?Product=3068
nitram38
posted on 14/4/06 at 10:45 PM Reply With Quote
If it is good enough for the atom, it is good enough for me!
C10CoryM
posted on 15/4/06 at 01:10 AM Reply With Quote
OK, Im a dummy. Where is the invisible safety washer in that pic? Usually its a large one on the outside. Ive never seen any other type.
"Our watchword evermore shall be: The Maple Leaf Forever!"
nitram38
posted on 15/4/06 at 07:56 AM Reply With Quote
There are none!
<<  1    2  >>
