Author: Subject: Laptop turning itself off!
xxx
posted on 15/4/06 at 07:25 PM Reply With Quote
Hi guys woundering if anyone has any ideas how to solve my problem:
Basically if I leave alone for about 30mins it just goes off straight away
It doesnt seem to shut down just goes off but then it starts up as normal afterwards
I have checked the power management settings and theyre fine
I have restored the computer to the time before the problem first occured (i think)
If I am using it its fine and stays on
Once noticable thing is when it restarts it doesnt svae my msn settings (i.e. if I change my name or pic it reverts back to the original)
Thanks in advance
Colin
jonno
posted on 15/4/06 at 07:39 PM Reply With Quote
Is it getting hot ? many power down if they over heat, check fans are working & clean etc
graememk
posted on 15/4/06 at 07:43 PM Reply With Quote
is it a packard bell or a HP by any chance ?
jonno
posted on 15/4/06 at 08:22 PM Reply With Quote
Sorry just re-read, its fine when using !! doh. ignore my comments..
wilkingj
posted on 15/4/06 at 08:36 PM Reply With Quote
Hmmm POwer Save settings?? ie no use and it suspends itself and switches everything off to save battery power.
Best Regards
Geoff
http://www.v8viento.co.uk
ReMan
posted on 15/4/06 at 09:49 PM Reply With Quote
Thats a power mangment setting of some sort.
Check your sceensaver setting isn't "turn off"!
Could (unlikely but possible)even be a BIOS setting
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
jonno
posted on 15/4/06 at 10:00 PM Reply With Quote
Thats what i thought to start with but xxx stated " I have checked the power management settings and theyre fine
mark chandler
posted on 15/4/06 at 11:12 PM Reply With Quote
My Dell laptop running XP has extended battery commands in BIOS.
However to be honest its a bit pants as after 15 minutes it goes to sleep and rarely comes up if left on batteries alone.
Regards Mark
shortie
posted on 16/4/06 at 06:16 AM Reply With Quote
I had a Siemes Fujitsu laptop which did exactly this, was because it was overheating as the heatsink got covered in dust and therfore it overheated and has a thermal cut-off on it.
I bought myself a laptop cooler and also cleaned out the dust and all worked fine.
HTH,
Rich.
xxx
posted on 16/4/06 at 01:21 PM Reply With Quote
Thanks for the replies guys. I thought it would have been the power management tools, its a toshiba satellite and so comes with toshiba power management which has always worked fine. I usually have my laptop plugged into the mains and it still shuts off. My next thought was overheating but wouldn't it turn itself off even when I am using it?
How do you clean the dust out? Take the cover off? (silly question but thought id make sure!)
Thanks again
Colin
