New Topic New Reply
Author: Subject: Rear Lights
mike smith1
posted on 18/4/06 at 11:54 AM Reply With Quote
Rear Lights
Comments on layout please and any advice, ref to setting out to meet final ride height of car etc and anything else you can think off, will try and attach the picture if not, it will be in my archive!
Mike
DarrenW
posted on 18/4/06 at 12:08 PM Reply With Quote
I like them. Look perfect. i much prefer the round ones set at an angle. Id say youve got it about spot on.
mookaloid
posted on 18/4/06 at 12:09 PM Reply With Quote
I like it. I see you have them a bit higher than I did - this is a good thing - I forgot about the minimum height thing and had to lift the rear end on the springs and run high tyre pressures to get through the SVA
mookaloid
posted on 18/4/06 at 12:10 PM Reply With Quote
You will need some stick on reflectors too - mine fell off shortly after SVA
shortie
posted on 18/4/06 at 12:24 PM Reply With Quote
Look nice mate, only my personal opinion but I like the fog light in the centre but obviously completely up to you, after all it's your car!! :-)
I assume the number plate light is going just above the number plate.
Also the reflectors will need adding.
Whatever you choose I reckon it looks good, nice job.
Rich.
eddymcclements
posted on 18/4/06 at 02:01 PM Reply With Quote
I like it. My own preference would be for an offset fog, just as you have it. Symmetry is over-rated! Nice high-level brake light, too.
Eddy
ReMan
posted on 18/4/06 at 02:10 PM Reply With Quote
Looks good to me
mike smith1
posted on 18/4/06 at 02:35 PM Reply With Quote
Thanks for all the replys so far, keep them coming, what is the rough ride height I should expect from the car so i can double check the hegights etc.
Mike
zxrlocost
posted on 18/4/06 at 02:46 PM Reply With Quote
I have 16" wheels 45 prof
my protechs are new
and are lowered so that there is about 3 lines of thread left on the shock bottom
my light sockets same as yours mike are 7cm from the bottom of arch to bottom lip of light housing
this makes around 350mm total gap which is correct for sva
although even on almost this setting which should be low theres a hands gap between wheel and arch so it best soften a bit cause it looks shite
New Topic New Reply
