Author: Subject: Lobster back bends!
owelly
posted on 19/4/06 at 03:11 AM Reply With Quote
Lobster back bends!
Has anyone got a method of making patterns to make lobster back bends?
I made an extention piece to move my throttle body to clear the camshaft pulleys but I'd like to 'bend' it so it's in a better place for attaching to the AFM.
In the past I have messed around with bits of card to make patterns but if someone had a 'puter program or an easy way, I would be very greatfull.
Cheers.
http://www.ppcmag.co.uk
NS Dev
posted on 19/4/06 at 09:29 AM Reply With Quote
off the top of my head won't it be total angle required divided by number of segments required, then divided by 2 to get the angle to set the saw to?
907
posted on 19/4/06 at 04:40 PM Reply With Quote
The more segments you have, the better the flow.
The downside of this is more segments = more work.
22.5 deg is the norm (cut at 11.25 deg)
I cut mine on a band saw. I tack a piece of box on the end of the pipe
so each time you turn the pipe over to make the next cut you can keep
them in line by placing a bubble on the bit of box.
If the cuts are not in line with each other the bend tends to become a spiral.
See cock up below.
owelly
posted on 19/4/06 at 07:14 PM Reply With Quote
I forgot to mention, I'll be crafting the bends out of sheet steel!!
907
posted on 19/4/06 at 08:32 PM Reply With Quote
If the pic below is gobbledygook and you cant find anything on the web send me the dims and I'll develop a patten.
I've got a dicky knee at the moment so I cant work on my car. I could do with a desk job.
owelly
posted on 20/4/06 at 12:25 AM Reply With Quote
Cheers 907. I'll have a measure!!
907
posted on 20/4/06 at 04:54 PM Reply With Quote
I'd need O/D or I/D, thickness of sheet, number of segments, and rad of bend.
atb
Paul G
[Edited on 20/4/06 by 907]
owelly
posted on 22/4/06 at 02:17 PM Reply With Quote
Here goes Mr G!
the O/D is 78mm.
The thickness of the sheet is 1mm.
Six segments should do it.
And the centerline radius something like 150mm.
I hope this makes some sense?
Cheers, Owelly.
907
posted on 23/4/06 at 10:53 AM Reply With Quote
Right then Mr Owelly,
I've done the drawings, but if I scan them and print them in Wizard they don't come out the right size.
I scanned and printed them in Photoshop and they are now the right size.
To check the rad is 150mm, the long side of a segment is 50mm, and the short side is 29.5mm.
The length of the developed shape is 242mm.
You need to download and print them without them expanding or shrinking.
Tape the developed shape to a sheet of metal and dot punch through the paper to transfer the shape
onto the metal, then cut it out. You then have a metal template that you can scribe round to make more.
Sorry to anyone else for the big pics.
If you have trouble printing them to size then I'll pop them in the post.
HTH
907
posted on 23/4/06 at 10:57 AM Reply With Quote
I should point out that a six segment bend is five segments, and a half segment on either end.
owelly
posted on 23/4/06 at 08:32 PM Reply With Quote
You are a beautiful person!
I will repay you in biscuits should we ever meet!!
907
posted on 23/4/06 at 08:51 PM Reply With Quote
Please keep them in an airtight tin.
I hate soggy biscuits.
atb
Paul G
owelly
posted on 23/4/06 at 08:56 PM Reply With Quote
U have U2U!!!
owelly
posted on 26/4/06 at 09:00 AM Reply With Quote
Many thanks Paul! I'll post some piccies very soon!!
the_parson
posted on 27/4/06 at 10:12 PM Reply With Quote
Did someone mention biscuits?
907
posted on 27/4/06 at 10:16 PM Reply With Quote
What are you doing up at this time of night??
Hot drink and a digestive and off you go
posted on 28/4/06 at 06:26 PM Reply With Quote
Sounds like Geoff may have competition!
907
posted on 28/4/06 at 07:19 PM Reply With Quote
No way.
Geoff pales into insignificance.
Huntley & Palmers deliver direct to Nick's house.
Paul G
owelly
posted on 5/5/06 at 01:26 AM Reply With Quote
Here's the finished lobster!!
But I forgot to deduct the angle of the end of the air plenum so the TPS was too close to the cam pulleys. That's what happens when to take things to work to make when to car is at home!!
So I swiftly chopped a segment out and zapped it with the MIG.
Many thanks to Paul G!!!
[Edited on 5/5/06 by owelly]
posted on 5/5/06 at 07:14 AM Reply With Quote
Does that welded word on the frame really say "LARD"?
MikeR
posted on 5/5/06 at 07:38 AM Reply With Quote
Of course it does.......
LARD - Left Assembly, Right Down.
owelly
posted on 5/5/06 at 08:26 AM Reply With Quote
LARD!!
I weld LARD into everything! Trailers, cars, boats, hats etc.....
It's a throwback from the days of Team Lard Racing, which was a bunch of hopeless baffoons packed into the Lardy-Van with a load of crusty old racing motorbikey things. It's a good way of recognising things after they get stolen!!
MikeR
posted on 5/5/06 at 04:57 PM Reply With Quote
can't argue with the idea
wilkingj
posted on 5/5/06 at 06:54 PM Reply With Quote
ARRRRGGGHHHHH!!!!!
I am insignificant now!!!
Huntley and Palmer... Pooh!!
Hob Nobs forever
No way.
Paul G
Best Regards
Geoff
http://www.v8viento.co.uk
