<<  1    2  >>
New Topic New Reply
Author: Subject: disappointing welding tests
PerspexIt
posted on 3/4/03 at 07:23 AM Reply With Quote
i'm here at office, thinking about what went wrong with my welding tests yesterday evening.
As suggested in the books i have, i did some tests using a plate with good results, the bed was smooth, not to thin, not to thick.
Now it's some days i'm trying to weld two pieces of tube with very bad results.
Seems the welding bed attach well only to one tube, not to both.
The gap between the tubes is minimal (max 1mm) i spent a lot of time trimming the connection with a file.
So bad i dont have a digital camera for take pictures, i hope my poor english can explain the problem.
I'm using a DECA MIG 145A, argon+co2, 3/4 of the max power, about 1/2 of the max wire speed.
The only doubt i have it's about the wire, i still use the two boxes was included in the cost of the welder. This evening i'll try with a new box.
Can be a problem of settings? Materials? Or just my fault?
Any help, in this dark, raining day.. is welcome!
-P
posted on 3/4/03 at 09:38 AM Reply With Quote
Practice, practice, practice... ;o)
Welding into a corner is one of the "medium" skills. You have to ensure that your torch is just about at an equal angle to both pieces (i.e. 45 degrees from each piece for a 90 degree joint) with the wire going directly onto where the 2 pieces join. I would guess that this is your major problem.
Some people like to weave very slightly from one side of the weld to the other, but this shouldn't really be necessary.
Gas flow shouldn't be a concern if your flat welds are good, as the shielding will be better into the corner.
Be sure to make life easier for yourself - ensure that the metal is clean and grease-free. Make sure that the wire isn't wobbling around in a worn tip.
You should only need about the same volts and wire speed as for a flat weld between 2 pieces of steel plate - in fact I've sometimes found that I've needed to reduce heat input a bit.
Are both pieces the same thickness? If one is thicker than the other then the skill level required rises a bit (you have to put more heat into the thicker bit by increasing the angle of the torch, and/or weaving fractionally more towards the thick piece and less to the thin one).
Hope this helps!
PerspexIt
posted on 3/4/03 at 10:27 AM Reply With Quote
Thank you very much for the help David! A bit of optimism is back now. This evening i'll continue with my tests.
Thanks again
-P
welshy
posted on 3/4/03 at 10:28 AM Reply With Quote
Woudn't it be easier if everybody used an arc (stick)welding set?
It is so much easier/quicker to get nice results.
I am not Welsh!!!!!!!!!!
James
posted on 3/4/03 at 11:32 AM Reply With Quote
You can get lovely results with arc if you're an expert- if you're not though it's blinkin hard! I've found arc far easier to blow holes in the metal and then unless you've done it well you've then got to chip off the slag.
It even says in the book that 16gauge is a little thin for arc.
IMHO of course!
James
leggin
posted on 3/4/03 at 11:51 AM Reply With Quote
you idiot
MIG IS FAR EASIER THAN ARC AND NEATER
posted on 3/4/03 at 12:03 PM Reply With Quote
Now, now, no need to be rude...
I've met a couple of welders who would cheerfully weld 1mm sheet with a stick welder - no blow holes, and the slag clicked off as it cooled, leaving an immaculate weld.
Trouble is, it took each of them 30 years of practice to get that good!
MIG is best for amateurs like wot most of us are... ;o)
DJ
[Edited on 3/4/03 by David Jenkins]
stephen_gusterson
posted on 3/4/03 at 01:54 PM Reply With Quote
my slight disagrement with David (who isnt an idiot :0) ) is :
I WOULD recommend, and I think its in several guides, that you SHOULD move the torch in a slight zig zag, or you may tend to get most of the heat in one part of the steel only.
On my little 100A welder, im pretty sure that its virtually essential to do this.
atb
steve
posted on 3/4/03 at 01:57 PM Reply With Quote
What do you mean by saying that I'm not an idiot! I'm very proud of my status, and have worked hard to achieve that ranking!
erm...
DJ
8-)
stephen_gusterson
posted on 3/4/03 at 02:05 PM Reply With Quote
erm...
DJ
8-)
Well, idiot or not, you are a fast one!
I only posted that 2 mins ago.
Looks like we both have a rushed day down at 't mill.
atb
steve
Mark Allanson
posted on 3/4/03 at 05:46 PM Reply With Quote
Are you welding downhand? If so the weld pool will run over the workpiece giving what looks like a good weld but will have virtually no penetration. On tube, ALWAYS weld upwards or horizontally, never weave the torch unless you are putting down a second pass over a root weld. Another thing to remember is to push the torch forward along the weld path, not drawing it back, and at about 80 degrees to the workpiece, but as been said earlier, split the angle between any joints, but still 80 degrees to the weld path.
My home welder is a clarke 140, about 15 years old but still going strong, my wire speed is about a quarter up the scale when welding with 3/4 power, if you have the wire too fast you may be compensating by welding too fast and again getting very little penetration. Although my welder is designed to take 15kg wire spools, the flywheel effect of the larger spool gives a jerky effect to the wire feed and will only get really good results with 5kg spools.
I hope this does not confuse the issue any further!?!
Mark
Viper
posted on 3/4/03 at 09:01 PM Reply With Quote
On Tube allways weld uphand?????????????????????????????? is it still April 1st??
This is 16swg we are talking here.....if you can't get full penetration downhand on 16swg wether its tube or rhs or whatever then you are doing something seriously wrong...
Alan B
posted on 3/4/03 at 09:29 PM Reply With Quote
Hmmm?....a little controversy here....
(was going to say "fight, fight fight"....but that would be childish!)
I'm with Viper on this in 25 years of welding I've never MIGed anything under 2mm thick upwards...always down...nor am awre of any weld failures either.....
The debate continues....
No disrespect to Mark BTW who is obviously experienced too.
Viper
posted on 3/4/03 at 09:40 PM Reply With Quote
Just for the record i am a lloyds registered welder...
Alan B
posted on 3/4/03 at 09:50 PM Reply With Quote
Looks like I sided with right guy....he he..(joking Mark)
For the record I used to have a Lloyds bank account....(true, but another joke)
Sorry guys I'm just very jovial today....
Viper
posted on 3/4/03 at 09:54 PM Reply With Quote
Suns out huh?
lucky bugger
Alan B
posted on 3/4/03 at 10:05 PM Reply With Quote
It's not actually...miserable and overcast..:-(
Viper
posted on 3/4/03 at 10:19 PM Reply With Quote
the wife is bending my ear, she wants to know what time it is over there and is mumbling something about holidays..must keep her away from the vodka
Alan B
posted on 3/4/03 at 11:12 PM Reply With Quote
It's 6.12 now...5 hours ahead....make sure you come and say hello if you do come over....:-)
Alan B
posted on 3/4/03 at 11:30 PM Reply With Quote
erm....that's 5 hours behind...you are ahead..
79 civic
posted on 3/4/03 at 11:33 PM Reply With Quote
i have a very similar welder, i use max power and i use between 5 and 6 speed
79 civic
i have a very similar welder, i use max power and i use between 5 and 6 speed this has good results
Mark Allanson
posted on 4/4/03 at 07:58 PM Reply With Quote
Viper,
I am also Lloyds certificated, I have ASME IV 6G MMA, BS4872 in arc, mig, and tig, and have been a part time lecturer at Cornwall College. I have worked at Hinkley Point Nuclear Power Station as a construction welder and 10 years as a Welder fabricator, but now work in the Crash Repair Industry.
You and I can weld uphand, down hand and even do little pictures of mickey mouse unsupported using MIG with the wire speed turned up, but the poor chap who originally posted this thread cannot.
I thought if he is welding down hand, producing a weld pool which is being supported by over advanced wire speed, the weld pool would barely touch the workpiece and would be 'balanced' on the end of the wire. It is just about the only way I could produce a good looking weld with zero strength.
If he welds uphand, this would be impossible, and I suspect the wire speed is too fast for the amperage. It is a common fault, most wire feeds are designed for an entire range of welders and if using 0.6mm wire with moderate amperage, the wire speed control would be in the lower 1/4 of the scale if the welder is capable of using 0.8mm or even 1.2mm wire.
Have you any further ideas why an externally good looking weld would have no penetration?
No hard feelings
Mark
Viper
posted on 4/4/03 at 08:25 PM Reply With Quote
no hard feelings taken
(asme9 g5 mma)
the first thing that struck me was he said he was getting a good run on one tube only, so no matter how much penetration he is getting the tubes won't stay together...obvious i know but if the run he is getting is good then is he using a magnet to hold the two tubes? perhaps that is pulling his arc, this i would have thought he would see unless he is using a very dark lens (god bless modern headshields) it is difficult to diagnose a problem when you can't see what is going on.
Mark Allanson
posted on 4/4/03 at 08:41 PM Reply With Quote
I had not thought about welders hands (magnets) causing the problem, I have never had much of a problem with arc blow with mig, but it can be a real sod with DC MMA.
Without seeing any images, I think it's a toss up between wire feed and/or torch angle. Bad earth location (doubtful) could cause problems.
Perplexit, can you post any images so we can help you out?
Mark
<<  1    2  >>
New Topic New Reply
