NS Dev
posted on 25/4/06 at 10:58 PM |
Vauxhall XE vs Ford Zetec engine weight
Just read some tosh on here about heavy Vauxhall engines.
No they are not light, but saying that in comparison to a Zetec is a bit far fetched to say the least!!!
Fully dressed Ford Zetec on twin carbs = 125kg
Fully dressed Vauxhall XE on twin carbs = 132 kg
Fully dressed Vauxhall XE with lightweight bits = 113kg
MikeR
posted on 26/4/06 at 08:26 AM |
fully dressed zetec with lightweight bits?????
i always find these figures interesting as its difficult to get an exact figure to compare, is fully dressed including fluids and electics? (ie an
engine ready to start?), what about engine management units? (ok so you said carbs) flywheel & clutch ?
I'm not having a gripe at how heavy or light any of the engines NS Dev's quoted, just the whole concept of this engine weighs.....
Fluke motorsport quote
crossflow (complete) at 81kg
crossflow 1700, carbs, clutch, oil, some water, starter 112
k series 1.6 supersport 105
k series 1.6 all ancilaries, flywheel, clutch, dry sump and engine mounts 102
K, with 5 speed, no alt or manifold 115
K, 1900cc, looks complete 89
zetec escort injection, no fluids, starter or gearbox 105
zetec at 127.5
zetec 2 litre, light fly, clutch, alt, inlet, carbs, filters and oil 122
xe all steel, 5.5" cluthc, fly, touring crank, arrow rods, cosworth pistons, jenvy throttle bodies, dry sump, high lift cams, no mounts or
alternator 112.8
xe, clutch, ali 5 speed box 140
xe (JPE spec) (bored typing now) 121
pinto 135 (no fluids, starter or gearbox)
NS Dev
posted on 26/4/06 at 08:30 AM |
yep fully dressed includes starter, clutch, alternator etc, not sure about exhaust manifold though?
DarrenW
posted on 26/4/06 at 09:25 AM |
What is also interesting you can probably fit a Zetec and an XE and still be lighter than my Pintosaurus
posted on 26/4/06 at 09:32 AM |
Pintosaurus...I like that
