Author: Subject: Gear shift linkage
liftarn
posted on 26/4/06 at 11:24 AM Reply With Quote
Gear shift linkage
How have you done it?
Fred W B
posted on 26/4/06 at 11:37 AM Reply With Quote
Like this
Fred W B
kb58
posted on 26/4/06 at 02:38 PM Reply With Quote
Push-pull cables using a modified Honda shifter assembly.
What kind of engine/tranny is this for?
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
liftarn
posted on 26/4/06 at 04:57 PM Reply With Quote
Classic SAAB 900. So it's an inline engine. That shouldn't change the basic idea, but it may need a longer link.
Oh, and I'm in Sweden so I will sit to the left and have the shifter to my right.
An interesting sollution I found on the SAAB Sonett mk1 is to have the shifter on the outside (right of the driver in a right hand driving configuration).
[Edited on 26/4/06 by liftarn]
liftarn
posted on 30/4/06 at 03:06 PM Reply With Quote
Got any pictures?
kb58
posted on 30/4/06 at 03:26 PM Reply With Quote
Only this one:
http://www.kimini.com/Diaries/Pre2003/shiftdone.jpg
It's a very modified Honda shifter and there are two push-pull cables. One cable selects row, and the other chooses column. The two cables go back, under the engine, curve upward and over to the transmission.
It was a fun puzzle, making sure when the shifter was done that first gear was still "up and to the right."
liftarn
posted on 1/5/06 at 02:08 PM Reply With Quote
Tricky. I think I'll have to go around the engine instead.
kb58
posted on 1/5/06 at 02:44 PM Reply With Quote
As long as you give the cables large bend radiuss it's be fine.
I worked out the shift mechanism on paper before building it. Oh and also have on hand the motion required for the various gears at the transmission end.
liftarn
posted on 1/5/06 at 06:53 PM Reply With Quote
Cables certainly sound easier than trying to make a mechanical linkage.
kb58
posted on 1/5/06 at 08:18 PM Reply With Quote
I'd prefer rods but in my application I was using a FWD lump in the back, the original shift locations are behind the engine and "pointing" to the left, so there was no straight shot.
OTOH if I had used an in-line 4-cylinder and VW transaxle, a rod shifter would work perfectly.
RazMan
posted on 13/5/06 at 02:29 PM Reply With Quote
I used a combination of rods & cables in my middy. The 8mm rods went from the Sierra gear stick and connected to the Sierra cables via a bell crank assembly (at the end of the tunnel) to reverse the movements. The cables then swoop under the transaxle and onto the standard link connectors.
The end result is a very quick action with much less slack than using cables all the way.
[Edited on 13-5-06 by RazMan]
Raz
kb58
posted on 14/5/06 at 04:31 PM Reply With Quote
Except now there are six points for additional play in the system: the pivots on the ends of the cable attached to the bellcranks, the bell-crank pivots, and the pivots on the end of the rods. It's also more parts, heavier, and probably more expensive.
That said, I agree rods are better; it's getting them around corners without adding play that's the trick.
RazMan
posted on 14/5/06 at 09:19 PM Reply With Quote
Actually I found there was less play in the rod & cable setup. My first try was using cable to cable (still on the bell crank though) and the action was really sloppy, possibly due to cable stretch over the 2.5 metre run. The rods took out the sloppiness and I'm really impressed with the resulting action. Using rose joints on the bell crank helped too.
Raz
