New Topic New Reply
Author: Subject: Will I fit into book chassis?
flidz101
posted on 27/4/06 at 08:47 AM Reply With Quote
I'm 6'4" will I fit into the book chassis or do I need to extend?
muzchap
posted on 27/4/06 at 08:55 AM Reply With Quote
Mate is 6ft3 - he fits in fine...
They are longer than you think ;-)
Only 'CONSIDERATION' is getter a Taller 'ROLL BAR'
The standard sized Roll Bar will probably be too low.
Roll Bar should be above your head for obvious reasons
[Edited on 27/4/06 by muzchap]
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
flidz101
posted on 27/4/06 at 08:56 AM Reply With Quote
I hadn't thought of that.
caber
posted on 27/4/06 at 09:05 AM Reply With Quote
Choice of seats, pedal box type and position, steering wheel size and inside leg measurement all have an influence, long legs are more difficult to accommodate than a long body!
Caber
splitrivet
Depends if you a 6'4" fat bastard or not.
Bob
zilspeed
posted on 27/4/06 at 09:12 AM Reply With Quote
Fat Ba***rds fit - it just means you don't rattle around.
Long legs are more difficult to accomodate.
As is a long back, come to think of it. I'm longer in the back than the legs and it meant I looked over the top of the screen with the seat in the car. Remove seat - job done. So - if you're 6'2" and generously proportioned like me, remove the seat and fit snuggly into the car.
ditchlewis
I,m only 6'1" but i'm a fat bas***d and i fit the Mk chassis..... Just well atleast i wont fall out.
Ditch
splitrivet
posted on 27/4/06 at 09:23 AM Reply With Quote
Will a cushion instead of a drivers seat pass SVA then Zilspeed.
Bob
zilspeed
posted on 27/4/06 at 11:24 AM Reply With Quote
Bob
You've got me there. Fit a seat and get a short a**e to drive it to the SVA, then modify as required post SVA....
P.S. Remember, if you're sitting that much further back, steering wheel is very likely to be too far forward and too low as well.
All borne of bitter experience.
posted on 27/4/06 at 05:39 PM Reply With Quote
Any reason that a bench style seat (as per Ron's book) would fail SVA? With a bit of foam scultping to fit your bum I reckon you could make it quite comfy. They give loads of room as well.
caber
posted on 27/4/06 at 09:27 PM Reply With Quote
I am planning bench seat arrangement for mine with padding on the outside and the tunnel at the hips. I have a Crapi axle and only 14" width on the driver's side!
Caber
caber
posted on 27/4/06 at 09:36 PM Reply With Quote
Caber
New Topic New Reply
