Author: Subject: Sierra Wiring Diagram
posted on 29/4/06 at 12:57 PM Reply With Quote
Hi, any one got a pdf or other format of a Sierra wiring diagram they can send me?
Hats off to you all for the bank holiday
steveridley@onetel.net
[Edited on 29/4/06 by coozer]
posted on 29/4/06 at 03:15 PM Reply With Quote
Its a Shappire Azure 1.6L Pinto from 1992.
I want to understand the whole wiring hareness so I can strip off the wires I don't need and use the rest on my kit.
planetester
posted on 29/4/06 at 05:11 PM Reply With Quote
you are better than me if you can understand the dim/dip system from the wiring diagrams.
good luck
[Edited on 29/4/06 by planetester]
RazMan
posted on 29/4/06 at 05:40 PM Reply With Quote
I've got a pdf I downloaded from a Russian website (I kid you not)
Coming your way soon.
Raz
posted on 29/4/06 at 07:20 PM Reply With Quote
Thanks chaps, got the diagrams now from you. Cheers!
I just need to trace the wires back that I need and uncderstand what the others are before I cut them out.
It helps to understand where all the bits and pieces are powered from.
Scratching your head without the diagram but easy deasy with the pictures.
posted on 29/4/06 at 07:21 PM Reply With Quote
Originally posted by CaLviNx
good luck
What dont you understand ? break it down in to little chunks to understand it.
Regards
well if it is anything like the mk2 escort, then that has me stumped; I can iunderstand the wiring but it does bot explain to me how the contacts are made when the levers are moved.
planetester
posted on 29/4/06 at 07:51 PM Reply With Quote
I dont really need to know anything, Ive rewired the sierra fuse box to do away with dim/dip, I have retained the use of the relays for dip & main beam & earthed them thro the column stalks
RazMan
posted on 29/4/06 at 09:50 PM Reply With Quote
Dim /Dip was always a daft idea anyway IMHO
Raz
