timmy
posted on 8/5/06 at 06:38 AM |
Duratec RWD gearbox options??
Hi all,
Does anyone know of a Mazda/Ford gearbox that will bolt straight up to a 2L Duratec out of the current Focus?
AFAIK it's the same as the new MX-5 engine, but there may be a Ford/Mazda commercial RWD box that fits??
This is a question on behalf of one of my fellow builders here in Oz. He just picked up a written-off 6-month-old Focus for the equivalent of 800
squid. And the engine has not even been run in properly yet. Some people have all the luck....
Tim
Fatgadget
posted on 8/5/06 at 07:29 AM |
Ford Ranger trucks are RWD and use the duratec.
http://www.duratecperformance.co.uk/forums/ubbthreads.php?Cat=0
zetec7
posted on 8/5/06 at 04:09 PM |
You'll probably find that newish Mazda trucks also use the Duratec/trans combination, if you can't find any Fords (Ford and Mazda truck
parts are interchangeable for the most part).
locost_bryan
posted on 9/5/06 at 02:22 AM |
The US Ford Ranger/Mazda B2300 (sold in Aussie as diesel Courier/B2500) use Mazda's M50-R1 gearbox. Same box as the RX7 Twin-turbo, but with
wider ratios.
Has a seperate bellhousing, so get a closer-ratio RX7 TT box from one of the importers and the B2300 bellhousing from Mazda, and Bob's your
auntie
or make your own adaptor for the smaller/lighter R-series MX5 trans (which has closer ratios anyway
Bryan Miller
Auckland NZ
Bruce McLaren - "Where's my F1 car?"
John Cooper - "In that rack of tubes, son"
