Author: Subject: Speedo Cable!
xxx
posted on 11/5/06 at 09:20 PM Reply With Quote
Speedo Cable!
Thanks for all your help on this forum, I finally get my car back and the road and....
The speedo stops working. The engine is a 1300xflow I am pretty sure there is a cable that runs from the dial and into the transmission somewhere! Ive been underneath tonight and had a look. It seems there is a small square hole in a little 'prong' that sticks out just before the prop and the cable seems to have been pressed into a square shape at the end.
Has it just fallen out and needs sticking back in? How do I secure the cable in the hole?
Pics (sorry for the quality, they're off my phone and I was in a very awkward position):
Cable and hole:
Hole:
Colin
mookaloid
posted on 11/5/06 at 09:25 PM Reply With Quote
there should be an internal circlip which goes inside the casting on top of the cable once it is pushed home.
I guess it has fallen out and got lost so you will need another.
Mark
Ketchup
if the cable still has the square end on it then it has not snapped at the gearbox end.. normally the cables cover has got a flared end that fits in the hole on the box and is secured with a circlip that sits in a small groove that you can just about see in the photo
Ketchup
posted on 11/5/06 at 09:26 PM Reply With Quote
beaten by a few seconds!
xxx
posted on 11/5/06 at 09:53 PM Reply With Quote
Cheers for the quick replies guys!
Any ideas where I may get such a part and what to ask for?
Thanks again
Colin
mookaloid
posted on 11/5/06 at 10:04 PM Reply With Quote
err ford dealer?
The circlip that holds the speedo cable into the gearbox?
Mark
