Author: Subject: wiring the brake sensor
ditchlewis
posted on 15/5/06 at 07:42 AM Reply With Quote
i have a sierra brake master cylinder with a float sensor with three connections on the top.
the vicky green wiring loom i have has two wires
how do i wire it up so it works?
is there another float sensor that i need?
Ditch
posted on 15/5/06 at 07:48 AM Reply With Quote
You will find that 1 wire is a common and the other 2 are switched - either one of these will do the job.
If you have a test meter (or a test light) find a pair of wires that give a connection when the cap is in its normal state (i.e. with the float downward) and an open circuit when the cap is inverted.
planetester
posted on 15/5/06 at 08:09 AM Reply With Quote
Mine a MK2 escort but I think the principles are the same, power goes to the bulb, then one of the wires goes to the switch on the m/cyl, the other wire then returns to the handbrake switch to act as a bulb test, the third wire on the master cylinder goes to earth & so earths out the bulb when you have no fluid, loads of people just wire up the handbrake bit, thinking the lamp is a "handbrake on" warning light, but the day they run out of fluid the true use of the lamp will not work.
good luck
flak monkey
posted on 15/5/06 at 11:06 AM Reply With Quote
I point you to here:
http://locostbuilders.co.uk/viewthread.php?tid=39092
Sera
http://www.motosera.com
posted on 15/5/06 at 11:13 AM Reply With Quote
The top of the M/C lid is also a test button. Press the black dome and a switch underneath it clicks, easier than taking the lid off to simulate low fluid. You don't need a handbrake warning light for SVA if you don't want to wire one in, just look at the lever to see if it's on .
[Edited on 15/5/06 by Peteff]
Danozeman
posted on 15/5/06 at 01:03 PM Reply With Quote
IIRC its the 2 outer ones?? I think thats what my VG wiring diagram says..
Dan
DIY Si
posted on 15/5/06 at 05:36 PM Reply With Quote
But you do need a way of testing the lamp from the driver's seat.
