Author: Subject: engine mounting dilemma
omega0684
posted on 29/5/06 at 01:40 PM Reply With Quote
afternoon all,
me and the old man went to trial fit the engine today, i spent all day yesturday cleaning all the muck and crap of the engine, so that it wouldn't be such a dirty job. anyway, got the crane in place with the engine hanging, as we began to drop the engine (pinto) into the chassis, we found out that its too narrow and there is about 2 inches either side of the mounting brackets!
am i missing something? i am using alloy pinto mounts if that helps anybody
any suggestions welcome!
ATb Alex
Bryan Sears
posted on 29/5/06 at 01:45 PM Reply With Quote
How about a bit of rubber.
flak monkey
Probably because the standard mounts arent long enough... You will probably need a set of proper dax mounts designed for the pinto. Either that or make some.
Sera
http://www.motosera.com
DIY Si
posted on 29/5/06 at 01:51 PM Reply With Quote
I would assume that, as with most kits, they are designed to use the manufacturers own mounts. It's also a nice way of getting a little extramoney out of you! Unless you can make your own that is.
omega0684
posted on 29/5/06 at 01:55 PM Reply With Quote
just looked in the DAX price guide and their 'SPECIAL ENGINE MOUNTING KITS' are £75 +VAT
DIY Si
posted on 29/5/06 at 01:56 PM Reply With Quote
See, told you
omega0684
posted on 29/5/06 at 01:59 PM Reply With Quote
smart arse
omega0684
posted on 29/5/06 at 02:00 PM Reply With Quote
si your good at welding, hows about you knock me up some mount extension brackets
DIY Si
posted on 29/5/06 at 02:22 PM Reply With Quote
you have u2u.
