Author: Subject: Renault Output Adapters
cs3tcr
posted on 7/6/06 at 06:50 PM Reply With Quote
This is probably dumb question, but who makes the adapters for a UN1 box to Granada half shafts?
Rod
minordelay
posted on 7/6/06 at 07:36 PM Reply With Quote
I think that car builders solutions do them.
Rene
posted on 7/6/06 at 08:00 PM Reply With Quote
Try google and you will find:
http://www.lamboreplica.co.uk/gearbox.html
and there is also an supplier in GB but I have to look for it.
lsdweb
posted on 7/6/06 at 08:41 PM Reply With Quote
Try Andrew in Bar Props - 01639 646922 - South Wales so may not be much use to you - he knows his stuff though!
MrFluffy
posted on 7/6/06 at 09:07 PM Reply With Quote
It did cross my mind to make my own.. I was thinking of taking the two original halfshafts, splitting the joint and turning one face off the original gearbox pieces to suit the ford halfshaft flange. That way I wouldnt need to mess round finding a broach to suit the splines etc. I havent done it to know its feasable, just been eying up the stubs and thinking...
I do have a lathe etc at my disposal, so if you had to find someone to work it all out and machine it , you will probally find its cheaper to buy the commercial ones..
v8kid
posted on 14/6/06 at 07:16 AM Reply With Quote
Interestingly the renault halfshaft has the same splines as fiesta hubs. The ABS teeth need to be cut off and a shorter locking nut fitted otherwise its AOK. I hav'nt got round to fitting oil seals yet but its looking good.
Not sure how long the fiesta hub will last!!
The specialist adaptors are way too expensive for me at £180 a pair and if my renault/fiesta pairing breaks I'd be interested if you could swop halves of the CV's
MrFluffy
posted on 20/6/06 at 06:40 PM Reply With Quote
adaptors
I wasnt really thinking about making a joint from two different parts, more that if you look at the original renault halfshafts, they have a thick alloy lump, and the commercial adaptors are just a spline one side with a dished face the other to suit the ford ones.
I reckon with some maching, you could cut a set of the renault ones to present a flat face to use a whole ford granada joint exactly like the commercial ones.
I just bought a un1 for 100 quid, does anyone want to murder me
v8kid
posted on 21/6/06 at 12:25 PM Reply With Quote
My Fluffy consider yourself dead.
Why can't I get deals like that was it OK?
v8kid
posted on 21/6/06 at 12:33 PM Reply With Quote
Phil I just read the rest of your message, so preoccupied with getting a UN1 for £100, - I've never seen a granada (lobro?) cv joint - is the diameter of the renault CV large enough to take the ford CV bolt pcd?
Reason I'm thinking of changing is that at Doune this weekend there was a rash of sheared drive shafts and the chaps were using similar power engines and similar sized tyres so I'm anticipating problems
MrFluffy
posted on 30/6/06 at 07:57 PM Reply With Quote
Dunno if the un1-013 is ok, havent picked it up yet.
For the output adaptor, check this page out :-
Thats just presenting a flange to mount the whole granny halfshaft joint on. What I mean is im not certain but maybe its possible to turn the same part from the renault originals...
