flidz101
posted on 11/6/06 at 03:02 PM |
Numpty ant-rattle clip question
I've been fitting mintex pads to my cortina front assembly and can't work out how the anti-rattle clip goes back into the (m16) caliper.
The Haynes manual just says "fit the clip"... how helpful.
Please can someone help? A picture would be great!
posted on 11/6/06 at 04:40 PM |
Try here
They seem to work perfectly well without.
jollygreengiant
posted on 11/6/06 at 04:48 PM |
IIRC 1 cut end into centre top hole on pad (each that is) and then clip should lay between the pads and 1 pin goes through "U" so that the
rest of the clip presses onto pad backing.
I think.
Its been 14 years since I fitted any.
