New Topic New Reply
Author: Subject: This is Confused Builders chassis so far
gjs
posted on 12/6/06 at 03:16 PM Reply With Quote
What do ya think ??
Marcus
posted on 12/6/06 at 03:24 PM Reply With Quote
It may be an optical illusion, but are you sure you can get a propshaft past the rear diagonal bit?
Just realised - it's prob IRS, so rear of prop doesn't move.
Liking the strengthening bits though.
Marcus
Because kits are for girls!!
Gav
posted on 12/6/06 at 03:25 PM Reply With Quote
Looks good, however hows the diff going to be attached or is it live axle and would their be enough room for movement of a live axle with out hitting the triangulation tube?, would of also thought you would need more than one big diagonal on the rear bulkhead.
carlgeldard
posted on 12/6/06 at 03:26 PM Reply With Quote
Looks good so far, But will that dia tube at the rear of the seats contact the propshaft.
Carl
carlgeldard
posted on 12/6/06 at 03:27 PM Reply With Quote
Dame beaten to it twice!!!!!!!!!!
gjs
posted on 12/6/06 at 03:33 PM Reply With Quote
Was going to be a live axle,now its going irs.Just the angle of the pic that makes it look a bit close to prop etc
posted on 12/6/06 at 04:12 PM Reply With Quote
Lovely bit of work... who did it?
Humbug
posted on 12/6/06 at 04:46 PM Reply With Quote
No upper tunnel tubes?
gjs
posted on 12/6/06 at 05:06 PM Reply With Quote
the chassis is Confused Builders,he's a member on here.Its not finished thats why there is no tunnel etc.He's going for the caterham/lotus look
mangogrooveworkshop
posted on 12/6/06 at 08:53 PM Reply With Quote
Very S3 with the round tube on the cockpit sides and the round at the back to support the ali panel.............mmmmm round topped transmission to finnish.
Nice work!
JonBowden
posted on 13/6/06 at 08:06 AM Reply With Quote
are the dimensions Caterham or Book ?
It looks nice.
More pictures would be welcome
[Edited on 13/6/06 by JonBowden]
Jon
andyps
posted on 13/6/06 at 12:53 PM Reply With Quote
Front end looks interesting - is that a rectangle at the base rather than the usual taper?
gjs
posted on 13/6/06 at 03:25 PM Reply With Quote
Not book dims just every bit of caterham info+guess work.Yes its a rectangle.A few more pics
ProjectX
posted on 13/6/06 at 10:28 PM Reply With Quote
Just wondering how you will get irs to work with the chassis rails behind seats?
Surely they are too far ot and will hit the driveshafts?
Also 1 brace for seat bulk is not enough. Twist from right (OS) will be transferred to NS lower etc etc causing more twist.
Just a thought.
Nice work tho
gjs
posted on 14/6/06 at 03:03 PM Reply With Quote
If you read the other posts it does say it was going to be a live axle setup first,but is now going irs so the bars your on about will be cut out and the chassis isn't finished thats why there is only one cross brace on the seat!!!!!!!!!!!!!!!!!!!!!!!!!
New Topic New Reply
