Author: Subject: how to shorten driveshafts?
gjs
posted on 15/6/06 at 02:40 PM Reply With Quote
Anyone done this at home with sierra shafts,or know of any sites that show how to do it etc
[Edited on 15/6/06 by gjs]
posted on 15/6/06 at 04:49 PM Reply With Quote
Luego used to shorten them for the IRS Locost , they did mine but I think if I were to build another with shortened drive shafts I would get new ones made . Think it was NSDev who posted a link for driveshaft manufacturers. May be worth a search?
NS Dev
posted on 15/6/06 at 05:04 PM Reply With Quote
GB Engineering
01270 841081
£80 each machined from billet, lightweight, heat treated EN27
trikerneil
posted on 15/6/06 at 05:07 PM Reply With Quote
Have a look HERE.
But I've only got 95BHP in 350Kgs
ACE Cafe - Just say No.
gjs
posted on 15/6/06 at 05:40 PM Reply With Quote
Cheers guys for the replies
Mr G
posted on 15/6/06 at 06:10 PM Reply With Quote
MK Engineering do them as well.
If the only option is shortening standard ones yourself then make sure you sleeve them.
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
Building: Built: V8 Kitten, 2 litre Lada, Space frame Minor,
posted on 15/6/06 at 07:26 PM Reply With Quote
Shortening Driveshafts
I have never done this but it should work.
The problem with drive shaftsis welding is not really advised due to the steel involved.
Therefore you can sleeve the outside and use 638 Loctite high strength retainer. If you get enough surface area it should hold.
The other option is silver solder. It will wick in and hold.
Anybody brave enough to try it?
Obviously surface finish and prep is vitally important, as is making sure they are straight.
If anybody is seriously interested I will explain how I would do this.
John
Wadders
posted on 15/6/06 at 08:08 PM Reply With Quote
All Stuart Taylors use shortened, sleeved and welded shafts, in fact i happen to have a pair for sale if your interested.... they are splined for lobros both ends.
russbost
posted on 15/6/06 at 09:35 PM Reply With Quote
Trust me - driveshafts can certainly be welded, I welded mine myself & I've broken a couple of bits in the drivetrain but not those, (see my thread under bec - bike engines have no torque ???!!!).
If they are solid steel. cut them get some interference fit sleeves, join at required length & a quick bead of weld at max power, Bob's your uncle, Fannys your aunt & away you go laughing
gjs
posted on 15/6/06 at 10:01 PM Reply With Quote
Hey Wadders can you post a pic of the shafts u have for sale
cheers
Wadders
posted on 15/6/06 at 10:58 PM Reply With Quote
Will do it tommorow, no problem.
cheers
Wadders
posted on 17/6/06 at 09:26 PM Reply With Quote
Pic as promised, sorry for the delay.
