xxx
posted on 16/6/06 at 08:53 AM |
Clearing up oil??
Hi guys while Ive had my locost down at uni Ive been storing it in a friends garage. Due to the problems I had with my sump and oil pump there is a
fair amount of oil on the garage floor. Basically is there any way I can clean up the quite large black patches on the concrete floor?
Thanks in advance
Colin
Tangerine Scream
posted on 16/6/06 at 08:59 AM |
I used the own brand driveway cleaner from Halfords/B&Q.
Surprisingly (for me) I followed the instructions and it managed to remove all evidence of an EP90 excursion
viatron
posted on 16/6/06 at 09:12 AM |
Cat litter to soak up the heavy patches then driveway cleaner, as already mentioned
Mac
grahamgg
posted on 16/6/06 at 09:24 AM |
use cement powder and leave over oil patches overnight ,brush off and jobs done.;);)
graememk
posted on 16/6/06 at 09:42 AM |
i drop kitty litter down then sweep it up in the morning, or just leave it as its not like its your garage
DIY Si
posted on 16/6/06 at 09:45 AM |
Cheap and nasty kitty litter. Last time I used it, the floor ended up cleaner than before I dropped the oil on it.
mark.s
posted on 16/6/06 at 01:40 PM |
try washing powder or saw dust if you haven't got a cat
dilley
posted on 16/6/06 at 02:12 PM |
any of the above, and then use some brake cleaner to really get rid of it.
zetec7
posted on 16/6/06 at 05:28 PM |
Boraxo powdered hand soap after kitty litter to soak up the wet part. That's what the shops around here use
andybod
posted on 16/6/06 at 08:31 PM |
soak up main spillage then use washing up liquid or a couple of washing tablets in hot water to break up the oil and wash away
trogdor
posted on 17/6/06 at 10:32 AM |
kitty litter is really good, as mentioned serveral times, we also use it to soak up the water that invaribly leaks in to our garage, just put a load
on the floor and move it round occasionaly to pick up water.
