Author: Subject: Exhaust mounts
JoaoCaldeira
posted on 30/6/06 at 06:36 AM Reply With Quote
Exhaust mounts
Hi all.
How have you mounted your exhaust?
Any pics?
Thanks,
Joao
RichieC
posted on 30/6/06 at 06:55 AM Reply With Quote
Hi Joao, Ive used the rubber lined strap off the bike and rivetted that to the underside of the floor.
You can use bobbins etc but I didnt need to.
Im changing the race can as its a touch loud to the original R1 pipe so I will take some pics then.
Rgds
Rich
[Edited on 30/6/06 by RichieC]
Humbug
Angle iron support bolted onto the chassis underneath, Land Rover engine mount rubber, strap made from ali.
[Edited on 30.06.2006 by Humbug] Rescued attachment 2005-06-11 5 ST silencer strap on mount and support.jpg
tks
posted on 30/6/06 at 08:12 AM Reply With Quote
Joa
You can also weld in the chasis side near your feet / 200mm from the seat an piece of angle.
than you drill that.
then you can just hang your exhaust with its original point to the chasis.
Will make a pic how i did it.
Tks
Bryan Sears
posted on 30/6/06 at 11:47 AM Reply With Quote
Hi RichieC I have MNR manifold and R1 exhaust did you get your link pipe from MNR? Bryan
jamesbond007ltk
posted on 30/6/06 at 11:50 AM Reply With Quote
Mine is essentially the same as humbug's except i used an mini tailpipe 'cotton reel' bush (Got it from my local car shop but found out the other day that Halfords sell them too).
Then angle like humbug and used an exhaust strap that is intended for oval exhausts and just bent it. Got this for a couple of quid from an exhaust centre.
RichieC
posted on 2/7/06 at 08:59 PM Reply With Quote
Hi mate, no the exhaust only came as the manifold.
I had to have the link pipe manufactured locally.
Rgds
Rich
GregMcN
posted on 2/7/06 at 09:25 PM Reply With Quote
Richie
Would be interested to see a picture of your link pipe - my R1 exhaust (inj) is larger bore than the manifold collector.
Greg
RichieC
posted on 2/7/06 at 10:08 PM Reply With Quote
Yep the bike has larger outlet from the collector, any custom exhaust place should be able to sort a link pipe with a little bending, cost me a fiver.
Ill get a pic tomorrow
Rgds
Rich
JoaoCaldeira
posted on 3/7/06 at 08:30 AM Reply With Quote
Originally posted by GregMcN
Richie
Greg
Both my link pipe and silencer come from MNR
The pic is on their site
Joao
RichieC
posted on 5/7/06 at 03:19 PM Reply With Quote
Richie
Greg
Photo as requested, I should have a stock R1 can on there at the end of the week so Ill post another as the link pipe will be different again.
Rgds
Richie
[Edited on 5/7/06 by RichieC] Rescued attachment DSCF0047.JPG
JoaoCaldeira
posted on 6/7/06 at 06:05 AM Reply With Quote
Richie:
Will that strap in the middle of the exhaust pass SVA?
Joao
RichieC
posted on 6/7/06 at 06:45 AM Reply With Quote
Which strap? The clamps will be wrapped for SVA so there will be no edges.
JoaoCaldeira
posted on 7/7/06 at 07:52 AM Reply With Quote
Hi Richie
In the body reflex you can see a strap (at least seems so...)
Joao
RichieC
posted on 7/7/06 at 07:54 AM Reply With Quote
Yep, thats the rubber lined strap from the bike
Rich
