jambo
posted on 7/7/06 at 05:47 PM |
zetec to mt75
hi there can someone who has this set up confirm what is required to get them together.
1999 blacktop 2.0l zetec to a mt75 gearbox.
thanks for any responce
Krismc
posted on 7/7/06 at 06:00 PM |
.....a head ache
Krismc
posted on 7/7/06 at 06:01 PM |
i tried gave up and then used a type9!!!
kevip6
posted on 7/7/06 at 06:02 PM |
Hi Jambo,
If you check out the Module 3 section of my website http://www.westfieldbuild.net/
It gives some details on linking my 2000 black top to an MT75
I basically needed a clutch spacer, and a spigot bearing, i got the sandwhich plate from a sierra but i'm not sure that made much difference.
The standard sump is a bit of a problem if you have a cable clutch (starter on the nearside)
HTH
stevebubs
posted on 7/7/06 at 07:49 PM |
You'll definitely need a
Release Bearing and Spigot Bearing
I *Think* most of the modern zetec-engined cars use MTX gearboxes. Also think the MTX and MT gearboxes are similar enough that you can use the same
clutch. Not 100% sure on this, though
stevebubs
posted on 7/7/06 at 07:51 PM |
More Information
kevip6
posted on 8/7/06 at 08:45 AM |
Hi, The Release Bearing is what i was refering to (incorrectly) as the spacer, this just replaces the standard MT75 one.
You can (and i have) used the standard Zetec clutch.
HTH
jambo
posted on 8/7/06 at 05:54 PM |
hi kevip6
you say you used the standard zetec clutch but with mine the splines on the gearbox shaft are much bigger than the hole on the clutch plate of the
zetec.
i have flywheel and clutches from both the 1.8 and 2.0l blacktops and the spline hole on them are the same.(dont fit)
any idea?
stevebubs
posted on 8/7/06 at 10:22 PM |
quote: Originally posted by jambo
hi kevip6
zetec.
any idea?
Try a 1.8 silvertop one?
jambo
posted on 8/7/06 at 10:52 PM |
funny enough 30 minitues later i bumped into a guy that gave me a 1.8l silvertop escort sump but is exactly the same as the 1.6l silvertop
stevebubs
posted on 8/7/06 at 11:04 PM |
?? Thought we were talking clutches and flywheels...
jambo
posted on 8/7/06 at 11:38 PM |
sorry mate my head is screwed with this boswallocks
ps the sumps my other problem
kevip6
posted on 9/7/06 at 10:17 PM |
Hi Jambo,
Thats odd, my engine came with the standard clutch on and it fit ok and i replaced it with a new clutch which also fit ok?
I'm not that technical so could there be a difference on the shaft on the MT75 depending on where it came from? I believe they were fitted to
Seirra's and Transits? Mine was from a Sierra i believe?
Sorry i can't be that much help but mine mated together straight off?
jambo
posted on 9/7/06 at 11:39 PM |
what year and type of car did your blacktop come from?
thanks jamie
[Edited on 9/7/06 by jambo]
kevip6
posted on 11/7/06 at 08:18 PM |
My blacktop was from a 2001 Focus, the engine was fitted in 2000 though (based on the letter from Ford Technical)
Don't know much about the car it came from though not sure if it was an auto or manual?
Hope this helps?
