Dick Axtell
posted on 18/7/06 at 09:07 AM |
MK Indy Bonnet Length?
I was certain someone asked this Q previously, but haven't been able to find it.
So, guys, what is the length dimension, measured along the chassis rails?
I'm using MK scuttle and nosecone, so I need to check if I can also use their bonnet!
stevec
posted on 18/7/06 at 01:09 PM |
Mine is 880mm along the chassis rail edge.
Hope this helps.
Steve.
Dick Axtell
posted on 20/7/06 at 08:58 PM |
Dimension - Yeah!
Steve -
Thanks for this info. Pls confirm it's from an MK Indy bonnet.
posted on 20/7/06 at 09:01 PM |
Ours is also 880mm and also an MK bonnet
Phil
Colnago_Man
posted on 21/11/06 at 11:19 PM |
On a similar vain could someone please tell me how wide the chassis is (outside to outside) at the front end of the bonnet, eg the point where the
bonnet meets the nose cose.
Many Thanks
Colnago_Man
posted on 24/11/06 at 08:58 AM |
Anybody Please? Dont want to spend the money on a new bonnet unless I know its going to fit.
Thanks.
Toady1
posted on 24/11/06 at 09:47 PM |
ive got my orange one to sell if you need it?
Colnago_Man
posted on 26/11/06 at 06:36 PM |
Thanks Toady, but I really need a black one.If its lying around I'd still appreciate a measurement of how wide it is at the bottom of the front
edge.
Thanks.
Jodieshann
posted on 23/1/14 at 11:11 PM |
I'd really appreciate the answer to this too. I need to know the width of the mk bonnet at the font and back to see if it will fit onto my
chassis. If anyone can measure a spare bonnet they might have or ideally their mk indy chassis width outer to outer where the bonnet meets the nose
and also where it meets the scuttle.
Cheers guys
40inches
posted on 24/1/14 at 08:26 AM |
Front chassis 67cm, rear 96cm. The bonnet will easily flex 20mm either side of these dimensions.
If the front panel of the scuttle is cut out, both the scuttle and rear of nose cone will flex easily by 12-25 mm
This may help in fitting:
[Edited on 24-1-14 by 40inches]
Jodieshann
posted on 24/1/14 at 08:49 AM |
Thanks 40inches, just the info I needed. My bonnet arrives from mk next week so need to have a play with it and see if it will fit. Otherwise I may
look at a gkd bonnet to go with the rest of the car.
kj
posted on 24/1/14 at 09:20 AM |
I have a spare bonnet with vents in and a hole for a carb if anyone wants it
Think about it, think about it again and then do it.
