Author: Subject: steering column mount
locoboy
posted on 23/7/06 at 04:02 PM Reply With Quote
Hi fellas,
Im putting in my steering column and have come across a bit of a hitch.
The small grey bush that the triangular end of the column passes through needs to fit into a mounting tube in the drivers footwell bulkhead.
Mine is a real tight fit in the tube, it will go in but it needs hammering in.
Am i right in thinking that this bush beeds to rotate in the tube?
even if i grease the bush its still going to be way to tight a fit to allow free movement of the steering wheel.
what are my options?
how have other manufacturers designed these mountings?
BTW its a GTS im building.
[Edited on 23/7/06 by locoboy]
Locoboy
Mark Allanson
posted on 23/7/06 at 04:17 PM Reply With Quote
The bearing should be a smooth sliding fit, shouldn't need any grease or hammering... It is this one your are describing? Rescued attachment Column Bearing.jpg
locoboy
posted on 23/7/06 at 05:11 PM Reply With Quote
Yes Mark that's the one.
All i have is a tube thats been welded through the footwell at a pre set angle which the grey bush goes into......... no bearing or anything fancy.
Heres a piccy
[img][/img]
Locoboy
andyace
posted on 24/7/06 at 07:43 AM Reply With Quote
Mine fits in easily and does not stick, no grease required.
posted on 24/7/06 at 07:48 AM Reply With Quote
The inner plastic bit should be an easy fit in the outer bit. However, the outer bit was a complete bar-steward to get into the rubber grommet that holds it in the mounting bracket!
Mike R-F
posted on 24/7/06 at 08:56 AM Reply With Quote
I don't think the 'tube welded to chassis' method of mounting the bush is the best approach. I know the Avon has this too. I tried this way first on my (self built) chassis but abandoned it in favour of the plate that holds both the outer & inner bush just as Mr Ford intended rather than trying to bash the inner into a bit of tube where it's a tight fit and probably running on a rough surface which will wear the bush out sooner rather than later. Bear in mind the dreaded self-centering test for the SVA. How is your car going to self-centre if the bush won't turn in the sleve?
BKLOCO
posted on 24/7/06 at 10:28 AM Reply With Quote
David.
The GTS chassis does not use the rubber grommet outer bit.
It just has a solidly mounted steel tube that is used for the outer bearing surface.
posted on 24/7/06 at 10:34 AM Reply With Quote
Ah... that explains my confusion!
