scotty g
posted on 30/7/06 at 07:46 AM |
clutch & flywheels for 1.8 zetec to type9 box?
Hi all, just so i'm sure in my head, what are you lot with zetecs using by way of clutch and flywheel combinations?
I have a 1.8 zetec and a type9 box, the engine has its flywheel/clutch so can i use it or do i need something else?
Cheers.
theconrodkid
posted on 30/7/06 at 07:51 AM |
those bits are ok,its the 2 litre wheel thats too heavy.
release bearing need modding tho,i think its a transit item with a longer carrier
who cares who wins
pass the pork pies
Danozeman
posted on 30/7/06 at 08:41 AM |
MIne is 1.8 with 1.8 flywheel and mondeo 1.8 clutch assy. and capri/old transit release brg. Quinton hazel part no cct133.
If u have the clutch try the friction plate on the input shaft of the gearbox because the newer mondeos have diffent size plate with smaller shaft.
this may help
Dan
