Author: Subject: Fuel capacity?
Fred W B
posted on 18/8/06 at 11:05 AM Reply With Quote
Fuel capacity?
How much fuel capacity do you think you need for road and track use? Considering I am using a RV8, I thought I had decided, but now I am having second thoughts, so what is everyone else doing?
Fred W B
Hammerhead
posted on 18/8/06 at 11:28 AM Reply With Quote
maybe finding the capacity of the RV8 engined TVR's will give you a possibility.
Delinquent
posted on 18/8/06 at 12:20 PM Reply With Quote
asked a similar question elsewhere and got told a multitude of different answers - very different project but probably similar in jiuce drinking.
Most recommended around 8 to 10 gallons for reasonable road use, so I've gone for 2 x 5 gallon tanks.
I looked at a few road car specs from an old civic (9 gallon) up to TVR's (12-15 gallon dependant on model) Some cars I found went as high as 24 gallons but even in my design, which is quite large, I've got no-where to put that amount unless I start putting cans in the passenger seat!
[Edited on 18/8/06 by Delinquent]
Dutchman
posted on 18/8/06 at 01:01 PM Reply With Quote
I think that tank shoud be at least good for 500km or 300miles ... 55-65 liter aproximatly depending on the engine , it is lamy to stop on every hour on gas station ...
Tarzan English with foreign accent!
chrisj
posted on 18/8/06 at 04:33 PM Reply With Quote
I settled on a double height tank or 50 litres but use baffles/foam, otherwise you have a dancing fuel guage and a misfire on corners.
gttman
posted on 18/8/06 at 05:57 PM Reply With Quote
An Ultima has 72L (twin tanks) and I am going for 85L with an option to go 95L if design allows.
My Ultima with its 6.3L SBC could do around 200miles on its tanks, on my GTT I want 3-400miles.
On the other end of the scale my Indy only has around a 20L tank... but then thats only a 1L engine!
Andygtt
Please redefine your limits
v8kid
posted on 22/8/06 at 11:32 AM Reply With Quote
Fred,
I have a 2 gallon tank good for about 5 miles tops. Running standard rover v8 on carbs
v8kid
Fred,
