Author: Subject: Is copper pipe ok for brake pipes?
ADD
posted on 26/8/06 at 04:28 PM Reply With Quote
another question....
Does anyone know if copper pipe is ok for brake lines?. I have done a search on here but get mixed responces, most say maybe some say no. I have just got some from a motor factors which says it is specifically for brake lines, so am reasonably certain that it is ok but need to make 100% sure before I go fitting it.
Again, thanks in advance.
Adam
fesycresy
posted on 26/8/06 at 04:42 PM Reply With Quote
As long as it's specifically brake pipe copper it's fine.
View User's Profile View All Posts By User U2U Member   fesycresy 's Aim
John Bonnett
posted on 26/8/06 at 04:46 PM Reply With Quote
Copper is fine for brake lines and if it has been freshly annealed is easy to form. Make sure it is clipped to the chassis at 300mm centres and placed out of harms way.
Kunifer, a nickel/copper alloy is superior to copper being tougher and more robust and this is ideal for rally cars where its greater resistance to abrasion might be a life saver.
I have used both in my time but on the Phoenix I have gone for copper which i believe will be more than adequate.
John
ADD
posted on 26/8/06 at 06:16 PM Reply With Quote
Cheers guys, exactly the answer I was after, guess I will be fitting the brake pipes this week then.
posted on 27/8/06 at 09:52 AM Reply With Quote
NO !!! -- actually illegal in many countries.
Use proper 3/16" Kunifer brake pipe.
posted on 27/8/06 at 10:45 AM Reply With Quote
But perfectly legal in the UK, and has been used by many people for many years,
However, kunifer (copper - nickel - iron = cu-ni-fe) is better by far, whilst still being workable. Avoid steel tube unless you have a really good flaring tool. Kunifer is the preferred material by people like Volvo and RR, I believe (IIRC).
The older I get, the better I was...
roadboy
posted on 27/8/06 at 11:47 AM Reply With Quote
I prefer Kunifer as I believe copper can harden & become brittle, Kunifer is much stronger but still easily workable
Regds
Ian
Jude Performance Services
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
Building: Built: V8 Kitten, 2 litre Lada, Space frame Minor,
posted on 27/8/06 at 07:14 PM Reply With Quote
Brake Pipes
Use Kunifer if you can get it. It is slightly more difficult to bend than copper, but is more resistant to fatique.
Copper is real easy to bend but work hardens.
Steel is an absolute pig to flare as I found out trying to repair my daily driver.
John
