New Topic New Reply
Author: Subject: Wish boan panting/covering
ceebmoj
posted on 13/5/03 at 08:19 AM Reply With Quote
I have had a look back through the past threads and found lots of info on panting the chasy. But I want to know what you lot would suggest I do with my wish boans i.e. powder cote or paint and if I paint what with.
Hornet
posted on 13/5/03 at 09:14 AM Reply With Quote
emmm brush
ceebmoj
posted on 13/5/03 at 10:40 AM Reply With Quote
lol
very funy but ytou know I meant what tipe of paint
macbrew
posted on 13/5/03 at 08:11 PM Reply With Quote
MK told me if you aint sprayin it .. red lead & hardest paint you can afford.
Hornet's right though.... you definately need a brush !
I did mine with hammerite rippled and it looks sh!te, will spend a lot of time re-doing them.
Talking Sh!te is the result of one or two PAN GALACTIC GARGLEBLASTERS
DONT PANIC!
Hornet
posted on 15/5/03 at 07:07 AM Reply With Quote
Soz M8,, couldnt resist it..
anyways.... i red leaded and then top coated with hammerite smooth black.
I used one of them small sponge rollers.. gave an excellent finish with no runs or sags.
But since then, i have found that while doing small jobs on chassis... chips are appearing as if by magic on frame... maybe Hammerite wasn't such a good choice...
ceebmoj
posted on 15/5/03 at 07:30 AM Reply With Quote
So powder coating is not a good idea.
When you say hard paint what do you mean and could you give me some examples
craig1410
posted on 15/5/03 at 12:08 PM Reply With Quote
Is Red Lead and Red Oxide the same thing?
How about Red Lead with Black Household Gloss paint on top. Is this what you would describe as a "Hard" paint?
Craig.
PerspexIt
I think he mean two-pack paint, hammerite, this kind of things...
search in the archive for more examples, you'll find a lot of posts about this topic.
-P
Jon Bradbury
posted on 15/5/03 at 12:51 PM Reply With Quote
Don't use Hammerite!
I understand Hammerite has a plasticiser that never quite sets, so it stays soft even when its "dry". That's why it keeps coming off. Personally I hate the stuff but because I'm not a paint sprayer its the only reasonable thing to use.
You might try getting the wishbones chrome or nickel plated. That's what I am going to do, if I can get the ball joint off (its screwed into the bottom wishbone just after welding, so the cooling / shrinking effect is supposed to lock it into place).
Meanwhile they're on the car and rusting...
Simon
posted on 15/5/03 at 02:08 PM Reply With Quote
I brush painted Hammerite (smooth) onto my wishbones to give a good thick coat, then once that had started going off, went over it with same paint in an aerosol.
Look great.
Used it on rest of chassis, ok, but has chipped. So would you if I hit you with a 200kg engine and box combo.
Jon,
Might suggest evenly and quickly heating wishbone with oxy/acetelyne torch. Hopefully expansion may allow you to remove balljoint. Once free I'd recommend re tapping the thread (without damaging/crossthreading).
Simon
[Edited on 15/5/03 by Simon]
Mark Allanson
posted on 15/5/03 at 06:39 PM Reply With Quote
Get them into a bodyshop, ask then to etch primer and then 2pack them in your chosen colour, if they wait until they get a car in the same colour and paint then at the same time, the costs should be quite low - I would probably charge about £30+vat as a guide
New Topic New Reply
